www.afrayspeed.co.uk/pages/45-tooth-gear-chart.xls
TS1 / Race Rapido Final Drive Ratio
NK 5.2
Fresco 4.8
Taffspeed 4.5 - 4.7
PM Tuning 5.1 - 5.3
DevTour (MB) 4.9 - 5.1
Kegra 5.2
JL KRP3 4.6
JL KRP4 4.7
Scorpion 4.9 - 5.2
ScootRS 5.2
Unfortunately, you will not see the BGM clubman on the list, however, much of this will also depend on how heavy/big you are and whether you intend to do much 2-up, live in a hilly or flat area, etc. all of which would influence what ratio you're looking for in top. Another 2 things to consider:
1. AF's original and basic guidance when the kit first came out was for 4.8 in top with a VW clubman or Fresco (as above in their current guidance), which I can assure you would still be the best all round top ratio for most grunty pipes, unless all of the factors are working in your favour; you're 7 1/2 stone, 4'5" tall, never go 2-up and live in Holland. 4.8 and you're not going to be far off.
2. Watch out for thinking that the BGM clubman allows you to pull very high gearing as whilst that might be possible with the RPM range of the pipe, the standard porting (port durations) of the TS1 mean that it will always produce best power at certain RPMs... if you make 4th so tall that you struggle to make those RPM then you will also struggle to reach the RPM where the power is. I often tout the line, 'if you want a TS1 to ride like a SIL stage IV then you really should have bought a SIL IV and saved yourself a heck of a lot of money and effort!', and I still stand by it. If you limit the RPM too much then you also limit the kit.
Please note that you may get away with 4.6 but only if factors are working in your favour. Remember that 4.8 works out roughly at 10 MPH per 1000 RPM so think about it in how hard your pipe revs and how fast you want to be spinning the motor. Many expansions will allow a reasonably ported kit to hit 10,000 RPM through the gears and even your BGM may reach or exceed 8K RPM if you hold it to the top of the rev range (no doubt a graph will be along shortly) and you should consider whether you want anything higher than that? (!) My iron 238 was spinning at 10K on Revival's open day at over 90 MPH and people were moving back away from the dyno as my bike sounded like a jet that was at risk of exploding!!!!
So, whilst others with a BGM clubman might come along to give you their 1st hand experience of gearing a TS1, remember that fit too high a ratio and you risk not getting high enough in the rev range to reach the RPM that the TS1 is ported to work at, but too low a ratio and you may find that the motor revs out too soon and/or limits higher cruising speeds. 4.8:1 = 10 X 1000, therfore:
6000 RPM = low rev cruising with clubmates at 60mph
7000 RPM = rpm picking up but happily touring with others
8000 RPM = starting to 'give it some' but happily still within the operating range of most decent Lambretta components (a decent clutch, decent bearings still cope with ease, etc) but nice to be able to use this additional power for overtaking or catching up with others when necessary. When you decide that you do want to use top end performance for such a manoeuvre, the last thing you want to be doing is finding that you're already revving out on short gearing or find that you open up the throttle and nothing happens as the motor doesn't really want to pull an overly long 4th, meaning that you need to drop to 3rd and scream its knackers off.
Another thing to consider about fitting a 4th that is within reach (workably short) is it means that you're likely to have enough grunt to easily span the 3rd to 4th gap that many peaky motors or pipes struggle with. A pal of mine runs a standard TS1 225 with LI125 and 18/47 standard GP200 sprockets (many hate this because of the 3rd to 4th % rise) and his bike pulls it perfectly, noting that he is not a heavy or big bloke. Again, this is because he has consider the motor as a whole, rather than looking at BHP figures of individual elements. When considering gearing he considered how the sprocket arrangement would allow him to get away with a fairly basic clutch, allow him to use a strong original Innocenti gearbox that he already had, combine this with a decent sized carb (30mm) and [importantly] a pipe that had good low RPM function but that also allowed enough RPM range to work in harmony with the TS1 port durations... so he fitted a JL3. Considering the motor as a whole unit in harmony, rather than randomly picking a selection of bits that are fashionable in 'pub chat' and dyno figures, has resulted in a bike that he loves to ride and rides beautifully. LI125 is still not 1st choice of box though if you have decent other options but do note the comment about sprocket influence on clutch requirement.
I'd look to aim for 4.8:1 and then tailor it to your needs from there, which you can do with a tooth more or less on the front sprocket, if chain allows.
Adam
