Page 3 of 4
Re: Ultimate Engine Spec - Based on New Casa Case
Posted: Tue Nov 29, 2016 10:48 pm
by eden
mick1 wrote:I notice the cranks a Pro Porting crank....isn't there a GT crank suitable ?
testing different web sizes, once its known what will withstand running in this motor I'm sure there will be a GT crank made for it.
Posted: Tue Nov 29, 2016 11:18 pm
by gerryjunior
crankshaft induction, looks very interesting, will they come air cooled also.
Posted: Wed Nov 30, 2016 12:32 am
by eden
gerryjunior wrote:crankshaft induction, looks very interesting, will they come air cooled also.
mid to late next year is the plan
Posted: Wed Nov 30, 2016 10:17 am
by holty
very nice eden, very similar to the rotax im doing, those cases would be perfect for me,are you putting a water feed into the crankcase or are you feeding it through the water connection on the exhaust, also does your inlet have a port going into the small boost port on the cylinder ?
thanks in advance
holty
Posted: Wed Nov 30, 2016 5:36 pm
by Rich_T
Water feed is into base of crank case (trying to feed through stub is a pain). Yes, the boost port cut out feeds into the side of the reed cut out.
Posted: Wed Nov 30, 2016 6:44 pm
by hungdog
Probably gonna be my next engine ... so looking forward to write up.
Posted: Wed Nov 30, 2016 10:15 pm
by Rich_T
Pipe will be finished in the next week and the inlet manifold the following week, after re-visiting the CNC for some adjustments. As it will take standard Lambretta electrics that will be a straight swap over. Carbs and water pump arrive tomorrow, last thing is the plumbing but it could all be set to run before Christmas...
Posted: Thu Dec 01, 2016 6:25 am
by RManson
I knew I should've just waited for you to figure it all out! haha
Looks amazing Rich. Should be a game changer!
Posted: Thu Dec 01, 2016 9:38 am
by holty
great work rich, very impressive indeed, are you expecting around the 40 bhp mark power wise ?
Posted: Thu Dec 01, 2016 1:05 pm
by racingskunk
Very impressive work! my keyboard is now full with saliva.....
