Page 3 of 4
Re: Race Tour Pistons
Posted: Fri Oct 21, 2016 11:08 pm
by dirtyhandslopez
ulyssescale wrote: I sent the piston away to have the top pin removed and replaced with a welded-in pin.
How does a steel pin get welded into an ali. piston? Put a loop in the pin, fit and weld round it? Just can't picture it
Posted: Sat Oct 22, 2016 5:58 am
by hendy
Alloy pin?
Posted: Sat Oct 22, 2016 11:04 am
by dave411
No,not alloy.Pressed in steel pins.
Posted: Sat Oct 22, 2016 7:31 pm
by ulyssescale
dirtyhandslopez wrote:ulyssescale wrote: I sent the piston away to have the top pin removed and replaced with a welded-in pin.
It is my understanding that is exactly how they do it.
Posted: Sat Oct 22, 2016 7:35 pm
by Muppet
hes got it right imo
Posted: Sat Oct 22, 2016 9:19 pm
by Bufficus
If they are as bad as their stators then best avoided.
Posted: Mon Oct 24, 2016 5:54 pm
by Grumpy225
Bufficus wrote:If they are as bad as their stators then best avoided.
Maybe it's a US thing but I've never had a BGM stator fail (installed 50 or so over the last 5 years). The only problem I've ever had with one was when it was run with a AF light flywheel. Anything above 7500rpm and the bike would misfire.
Proper ground points on clean metal with correctly crimped connectors = reliable electronics
Posted: Mon Oct 24, 2016 9:38 pm
by ulyssescale
I ran a v1 BGM stator for 7 years. The later ones had issues with RFI/noise at higher RPMs, but a filter was developed and the issue solved. Of course, that filter is a US$30 solution on top of the cost of the BGM stator.
Posted: Tue Nov 01, 2016 5:47 pm
by eden
Toot-oasc wrote:ulyssescale wrote: The cylinder was returned for repair. MB was as nice as he could be about it, but it seems unfair to make it sound as if MB is personally responsible. Failures happen. It is being repaired and I'm confident I'll be just as happy with it post-repair as I was before it failed.
I much prefer doing more riding than complaining.
You've had a level of customer service that I, and I know lots of others, haven't been offered when ring pens have failed on these pistons.
Maybe the message has finally sunk in that treating your customers like they are sh*t off your shoe doesn't help maintain repeat business?
I like nothing better than riding rather than complaining, however when large scale failures are occurring on a specific part you would expect a product recall, not to blame your customers with feeble excuses such as mixing oil....
Just setting out my own personal experience, I'm sure others can speak of their own experiences.
He probably just doesn't like you
Which is the one and only thing MB and I have in common
Posted: Tue Nov 01, 2016 5:54 pm
by cartmel808
eden wrote:Toot-oasc wrote:ulyssescale wrote: The cylinder was returned for repair. MB was as nice as he could be about it, but it seems unfair to make it sound as if MB is personally responsible. Failures happen. It is being repaired and I'm confident I'll be just as happy with it post-repair as I was before it failed.
