More problems, exhaust full of petrol
1) Do you turn your petrol tap off when not in use? If so....it's not working, check it out.
2) There has to be a fault with your floats and/or float valve. These items act as your 'ballcock' to stop flow, so of the flow is continuing...that's where the problem stems from.
drunkmunkey6969 wrote:1) Do you turn your petrol tap off when not in use? If so....it's not working, check it out.
2) There has to be a fault with your floats and/or float valve. These items act as your 'ballcock' to stop flow, so if the flow is continuing...that's where the problem stems from.
Snails
Yes turn off fuel when not in use - although it's much quicker than that - to get it started I flip fuel on and off get it running after lots of kicks and then if I turn fuel in when it starts to starve it dies. Then fuel will be leaking out of the exhaust after a few mins
I'll have another look at float etc but can't think what it could be. I'll maybe up load a video just in case there is something I'm missing
HxPaul
If your exhaust is full of petrol,then either your float is sticking and not allowing your float valve to close,or your float valve is not seating correctly.
Chris in Margate
Take carb off and expose the float assembly. Fit short length of pipe to fuel inlet. Blow through it and as you do then lift the float and note where/if it shuts off and you can't blow anymore. This will demonstrate if it's working ok. The fuel tap is really a red herring as your float valve is as previously excellently described a "ballcock".
If the float valve assembly is working then you don't need to shut off the fuel tap, although it is good practice to do so.
Snails
That's what I was thinking of doing as a test but with fuel and the chamber closed. Thanks for the tip
Snails
Here is a video of my test
http://youtu.be/505_ZPXcGgY
Scooterdude
Is it possible that you may be refitting the float bowl the wrong way round thus preventing the float from working correctly?
Snails
Scooterdude wrote:Is it possible that you may be refitting the float bowl the wrong way round thus preventing the float from working correctly?
It only fites one way unfortunately - good idea though
Scooterdude
well ok that rules that out. Now get a measuring jug and half fill it with petrol, take out your float and submerge it in said jug and petrol and look for air bubbles coming from the float, hold it there for a while and see if it sinks.
