Page 3 of 5
Re: More s**t parts.
Posted: Sat Jun 18, 2016 1:54 pm
by timexit17
Trouble is it isn't just the hassle of sending parts back it's the waste of a afternoon thinking 'am I doing something wrong' that I begrudge!
If I could charge for my normal hourly rate they wouldn't dare send out less than perfect parts!
Posted: Sat Jun 18, 2016 4:50 pm
by 10 inch Terror
And it continues. Only a small item but it held me up fitting the toolbox door. The top pin is way too short. That's 3 things from the same supplier that's not fit for purpose.
Posted: Sat Jun 18, 2016 4:57 pm
by DigDug
I've just spent all morning trying wrestle a "replica" Series 2 exhaust on to my Winter Model. Lovely bit of kit - even has an IGM number. The u bend fits, the silencer fits - they just dont fit together on the bike.
Dug out an old SIL standard box and u-bend and it fits like a glove!
That's after having spent half an hour fettling a regulator to fit a poorly made copy of SLJ's combined CDI/regulator bracket.
Posted: Sat Jun 18, 2016 7:13 pm
by MarkH
10 inch Terror wrote:And it continues. Only a small item but it held me up fitting the toolbox door. The top pin is way too short. That's 3 things from the same supplier that's not fit for purpose.
Series 1-2 pins are shorter than Series 3/DL.
Posted: Sat Jun 18, 2016 7:58 pm
by 10 inch Terror
MarkH wrote:10 inch Terror wrote:And it continues. Only a small item but it held me up fitting the toolbox door. The top pin is way too short. That's 3 things from the same supplier that's not fit for purpose.
I 100% ordered a series 3 one. Obviously an error their end and easy enough to make. It doesn't help me though when I have to order, pay and wait for for a new one to arrive.
Posted: Sun Jun 19, 2016 1:22 pm
by 10 inch Terror
Posted: Sun Jun 19, 2016 2:41 pm
by Scooterdude
You must have shrunk um by boiling. Best way to fit them I found was to spray the inside with women's hair spray then they slip on and when the hair spray dries they stick like glue.
Posted: Sun Jun 19, 2016 3:00 pm
by 10 inch Terror
Scooterdude wrote:You must have shrunk um by boiling. Best way to fit them I found was to spray the inside with women's hair spray then they slip on and when the hair spray dries they stick like glue.
I've not fitted or put the throttle side in boiling water and it's still too short. It's still the same size as the gear side. It 100% hasn't shrunk.
Posted: Sun Jun 19, 2016 3:32 pm
by garry inglis
i feel for you 10 inch one thing after another i am sure they should be 110mm long
Posted: Sun Jun 19, 2016 4:42 pm
by Scooterdude
10 inch Terror wrote:Scooterdude wrote:You must have shrunk um by boiling. Best way to fit them I found was to spray the inside with women's hair spray then they slip on and when the hair spray dries they stick like glue.
Well as I recently found out just cuz it says "Casa" on the packet it still may not be any good! I fitted Scootopia grips without a problem, Scootopia's chrome ring and headset bearings were a different matter though!
