Re: Does AF rayspeed really exist!?
Posted: Sun Jun 05, 2016 9:55 pm
I think it was more a case of the circlip and disc/washer letting go and then the piston getting stuck out and smashing the 1st gear kickstart teeth. But agree that all the other parts should have failed before the gear!10 inch Terror wrote:I'd of though a gearbox would be made of much harder material than a circlip. Surely the circlip should of been minced up not the kickstart teeth?ridden not hidden wrote:Mine was due to kickstart shaft piston failing but I have heard that they don't like high HP motors. If I can't get hold of AF I might end up putting a GP box in10 inch Terror wrote:Are these close ratio boxes made from cheese? Why are so many getting damaged?
