Tubeless Wheel Choice.
lamblast wrote:always cut the tires off tubeless rims its the only way .I use af rims with heidenau k61 tyres 93 mph rating made in Germany
I've seen these advertised but all the ones I've had have been J rated 62 mph and can't find a P rated one on Heidenau's website.
http://en.reifenwerk-heidenau.com/modul ... =52&pic=49
Even the new K80 is only M rated 81mph
http://en.reifenwerk-heidenau.com/modul ... 73&pic=120
Im using sip rims ans scoot smart tyres bought from martin I did get a new rear hub when I got mine so no problem changing studs also a nice disc brake atomic rear shock again all from martin
I recently fitted the anti dive to my scooter and I have bitubo outboard front shocks and I can say its the best handling lambretta ive owned the tyres warm up nicely and have great grip
lamblast
just had a look corrado ,your correct its my rear that's p rated as I run a 13 inch rear on my auto lambretta and not got a 10 inch on the front at the moment lol
I've spent an hour outside tonight, skinned three knuckles and managed to remove 4 studs from one rear hub using a combination of double nutting a ground socket and the blow lamp. SIP might at least be an option on the rear now.
Less optimistic about the front but I need to take it off to see why the brake is binding on a bit anyway.
Have ordered a pair of the Scootsmart tyres.
