Page 3 of 3
Re: TS1 Running Fast on Tickover
Posted: Tue Mar 08, 2016 12:32 pm
by ktmh5
Ok so I've done a full leak down test which was fine. Everything at the top end has been stripped, checked and re-built. Reeds are fine, all gaskets and surfaces are fine. Carb has been apart loads of times and is completely clean. Cables all checked out ok.
Any other suggestions, as this is doin' my head in!
Rich'
Posted: Tue Mar 08, 2016 1:27 pm
by servetakid
Rich, maybe try swapping the stator? It might be breaking down under load.
Posted: Tue Mar 08, 2016 1:39 pm
by ktmh5
servetakid wrote:Rich, maybe try swapping the stator? It might be breaking down under load.
Will have a look at that Jordan after changing the carb for a known working one off my other scooter.
Rich'
Posted: Tue Mar 08, 2016 2:16 pm
by servetakid
Stators can give some strange symptoms! I've had it where the only way you can keep the engine running is to have them at full throttle and they cough and splutter as if it's four stroking.
If you tried everything else, that's where I'd be looking.
Posted: Tue Mar 08, 2016 5:23 pm
by hungdog
CDI :?:
Posted: Thu Apr 07, 2016 3:21 pm
by ktmh5
Update on this, I have finally found the problem. It was an air leak as swan neck was loose and the whole pipe had dropped a touch leaving a gap where the pipe meets the stub. Loosened the swan neck off more, jacked the pipe up with a scissor Jack and re tightened the swan neck. Putting a bit of sealant on as well to be sure. Straight away it ticked over normally
Rich'
