Re: Cast iron VS Aluminium cylinder
Posted: Wed Jun 24, 2009 2:04 pm
Is there a template for port clearing that I could print and stick to the barrel to start cutting/filing the ports.
Thanks
El__burro
Thanks
El__burro
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
Just use a base gasket as a template.El__burro wrote:Is there a template for port clearing that I could print and stick to the barrel to start cutting/filing the ports.
Thanks
El__burro
The Mugello is hard to beat as an all around kit and it'll work well with a small carb and clubman or a big carb and expansion exhaust. Might be worthwhile matching the barrel to casings but apart from that it's pretty much plug and play. The ebay type SR kits are about one third of the cost but they're rarely plug and play so there's the expense of having it worked on plus P&P charges to take into consideration, plus the cost of fuel and time running it in for 1000 miles (it's more difficult than you think). I know of a Mugello kit that's done over 40,000 miles, i'm willing to bet that an SR kit won't do half of that including it's rebores up to 200cc.druist wrote: if you had a 175 iron some tuning done would it be worth going upto 190cc or wouldnt the gain be that much. Some seem to say 10 - 15mph extra which seems a fair bit. Are any of the low end kits worthwhile if tuned well or is an imola, rapido, mugello type kit needed?
