Re: Fuel starvation?
Posted: Wed May 20, 2015 9:39 pm
i had similar problems albeit with all levels of fuel.
Diagnosed it to a fuel tap in the end............had changed CDI, fuel pipe length and all sorts...........would run then die........leave it 10 secs and would kick again.........used to just go blleeeeeeurgh......... I think the breather tube on the tap was blocked / blocking and wasn't equalising the tank.........had changed cap too...........mine was a lot simpler than the things that you are doing.........check the simple things first like fuel cap, fuel tap and then start breaking it apart lol
