Page 3 of 4
Re: O-tuning V5A for my elder son (hot french recipe inside)
Posted: Fri Apr 10, 2015 8:35 pm
by fastfrog
Barrel and piston back from the workshop.
New timing with the 2,5 m packer under:
T:110°
E: 148°
I: 109-45° makes 154°
I need to rise the exhaust up to 160°. It's about 2,1mm to be removed.
BD:25°
I've got almost 4mm squish now. Guess it needs a good skimming job to get 0,85mm...
Posted: Fri Apr 10, 2015 10:46 pm
by fastfrog
Squish at TDC:
Packer being ported:
Posted: Sun Apr 12, 2015 10:34 am
by fastfrog
Main casing done and ported:
But got a prob with the right casing. A welding bubble has passed through where the stator takes place. There is a chamfered flat at this place where the wall is very thin.
Posted: Sun Apr 12, 2015 9:55 pm
by fastfrog
leak fixed with a putty of epoxy.
Exhaust port done. Only 160° but this small engine needs to keep enough guts at low revs... Keep in mind it's 130° on a std barrel....
Posted: Fri Apr 17, 2015 10:14 pm
by fastfrog
barrel and head skimmed off:
Head bolted on with a real squish band. Not the case with the original head.
Engine rebuilding is about to begin.
Posted: Sun Apr 19, 2015 3:29 pm
by fastfrog
Had to reshape (a bit) the head. Squish clearance between head and piston wasn't good with a negative angle at one step.
took my moviluty and did a little squish job:
almost done:
Posted: Sat Aug 29, 2015 11:03 pm
by fastfrog
I've been quite busy on several projects at the same and left the 50S alone a few weeks. I'm back on it. My soon just succeeded to his 50cc driving licence.
During his training:
Good news and it's time to accelerate a bit quicker.
Fresh painting:
Wiring loom and cables/sleeves in place:
Hydraulic conversion starting:
Engine's back in the frame:
first kick start: Seems to work.....
My new acquisition: APE50 country cross. So fun to drive it....
Posted: Mon Aug 31, 2015 2:40 am
by guygrrr
I'm excited to find out how well it goes down the road!
And, am I looking at the glossiest black paint job ever?
Posted: Mon Aug 31, 2015 1:56 pm
by fastfrog
I guess so..... Electrical wiring is almost finished First road try within a few days.
Posted: Tue Sep 08, 2015 3:09 pm
by jackson85
That's about these glossiest thing Iv ever seen. Looks like chrome!
