What The Fuel (WTF)!
Mr G in NYC
Main scooter: SX200
I hear ya Darren...I'm moving down south :lol: :lol: :lol: G.
meanwhile .........
My car is older than 2001. What should I do?
Don't fill your fuel tank with E15, simple as that. Even though the new fuel is coming to market, the gasoline or E10 you fill your tank with now will still be available. There is a twist, though. At gas stations that use blender pumps (a single spout that dispenses all octanes) you'll have to purchase at least 4 gallons of E10 to insure any E15 in the hose is diluted to safe levels in your fuel tank. Fuel pumps will be required to have a 4-inch-square label warning motorists not to use the fuel for uncertified engines. With that in mind, the best advice if you have an older car is to stick to stations that have not switched over.
Will this damage my lawnmower, boat, jet ski, snowmobile, or four-wheeler?
It sure will if you don't pay attention. Generally, small engines are not designed to deal with the more corrosive E15 blend. And, as we mentioned in 2010, ethanol forms a brown goo when left in a fuel tank too long, which can clog fuel-system components. Two-stroke engines run hotter with an ethanol blend, which accelerates the potential damage. And ethanol can wreak havoc on fiberglass fuel tanks in older boats. Groups like the National Marine Manufacturers Association and Outdoor Power Equipment Institute have issued strong warnings to consumers to pay attention to their fuels or risk severe engine damage. Use a fuel stabilizer if the engine will sit for more than a few weeks without use; this will reduce the ethanol–water separation and potential gumming issues. Be careful to avoid using E15 in uncertified engines like these, at least until the subject is studied more thoroughly, and the engineering catches up to the fuel.
