Page 3 of 3
Re: EGT temp and powerjet........
Posted: Wed Dec 24, 2014 2:52 pm
by alanscottj
rosscla wrote:I looked at it and concluded I'd need to remove a bit of fin and cut a bit out of the plug hole in the cowling to get it to fit.
It went on the cowling head bolt...
And are you happy with it there?
Posted: Wed Dec 24, 2014 4:17 pm
by eden
on the bolt works just fine, the readings are just a little delayed and lower then they are under the plug. I too had the cht on the bolt on my italian cast 250 due to the reasons you have stated. on the both GT kits I have its under the plug because the sensor fits fine on a porcupine GT head with out any modifications.
Posted: Wed Dec 24, 2014 4:58 pm
by rosscla
For now I am, as long as you know what the normal operating temp is you should be able to keep an eye on the trend.
If you have EGT and CHT you generally don't want to see the EGT going down and the CHT going up significantly, that's a bad sign.
