Looks a clean casing mate but has surface rust on crank webs and other items ? Check big end and cruciform looks well good for an old type gearbox
Got a good one there
Cruciform. There seem so many variations. Are either of these two OK?gaz_powell wrote:Paul
The cruciform on the early gearbox is a weak point (compared to the stronger EFL type) - defo change it and as GL said use only a genuine one (wasp) and a cush drive repair kit. Dont worry about the lip on the xmas tree. More so check the loose kickstart cog/gear - change it if showing signs of rounding and the kickstart buffers.
Gaz
I've done all that plus penetration oil and heatGLscoot wrote:.... the xmas tree rivets are easy enough to remove, I use a sanding disc on a grinder and a nail punch, you are not going to use either the metal cover or the rivets so you can be aggressive as you want. the springs will look ok but for the cost of replacing them out ways the risk of not, especially as you have the engine open.....
