Page 3 of 4
Re: TS1 bore wear
Posted: Thu Dec 18, 2014 7:36 pm
by nelson pk
eden wrote::shock:
im happy if everyone uses ali kits because it means my cast iron barrel collection keeps growing :)
tbh I only go on about cast iron barrels because they have served me so well for the last 33 years. Ive never felt the need to go down the ali barrel route even though nearly everyone I ride with either still use them or have used them in the past.
Some people used to take the p155 about my STONE AGE tunes on STONE AGE barrels, that tends not to happen so often now, I wonder why ;)
I would never say that you cant tune an iron barrel to go fast. Of course you can. Its just that i feel an ally barrel is more reliable if set correctly. Its what i am comfortable with.
Each to their own :D
Re: TS1 bore wear
Posted: Thu Dec 18, 2014 7:57 pm
by eden
agreed.. each to their own...
my tuned iron barrels aint slow and they do a hell of a lot of miles, I don't agree that ali is more reliable than iron.
I honestly think that iron barrels got a bad name back in the day before the TS1 came out just because most where just not set up correctly. The people who went over to the TS1 back then mostly never tried another iron barrel.
Another thing people say about iron barrels is that its a pain in the arse that you have to run them in a lot more than an ali barrel, that's very true if the clearance isn't right for the piston/barrel/bore combination but not true if these things are done right. as an example, my new 250 that first turned a wheel last Saturday now has only 180 miles on the clock and last night with only 140 miles on the clock I held it at 76mph for about a mile and it didn't nip up, today ive rode it to work and thrashed it all the way there and back and it still hasn't nipped up.
What most people think about iron barrels is just incorrect.
I had a rebore on another iron barrel earlier this year that kept nipping up at anything over 45 mph, I had the bored measured and it was found to be bored on the p155, it was much tighter on one side of the bore than the other and tight at the bottom of the barrel. once it was bored out straight it never nipped up over around 5000 miles until it was running close to flat out on the M5 with a huge hole in the exhaust racing a certain loony, it nipped up due to the hole in the exhaust weakening the carburation too much, even after that nip up it still ran with the hole in the exhaust the rest of the way home (over 85 miles) at 70mph.
If I had been on an ali barrel that day, the motor would not have nipped up it would have kept running for a few miles longer and eventually holed the piston meaning I would have had to be recovered. see the piston in my avatar? that came out of an ali barrel not an iron barrel.
As you say though... EACH TO THEIR OWN :)
Re: TS1 bore wear
Posted: Thu Dec 18, 2014 8:04 pm
by Muppet
:lol: it's marmite
Re: TS1 bore wear
Posted: Thu Dec 18, 2014 8:11 pm
by eden
Muppet wrote::lol: it's marmite
:lol:
Re: TS1 bore wear
Posted: Thu Dec 18, 2014 10:07 pm
by nelson pk
eden wrote:agreed.. each to their own...
Just a wild stab in the dark here......do you prefer iron barrels :D
Re: TS1 bore wear
Posted: Thu Dec 18, 2014 10:19 pm
by eden
beer barrels are the best barrels tbh, I doubt we will argue about that :)
Re: TS1 bore wear
Posted: Thu Dec 18, 2014 10:30 pm
by nelson pk
eden wrote:beer barrels are the best barrels tbh, I doubt we will argue about that :)
I agree with that for sure :D
Re: TS1 bore wear
Posted: Thu Dec 18, 2014 11:57 pm
by Trojan
Yep I agree with that also, been an interesting post to follow as we all have our opinions on which barrel to prefer, TBH its still a minefield to some with the pros and cons , either way , Fuel seems the suspect to most of the problems the both barrels have experienced, along with Timing being the issue, anyway thanks for the views and all the best for the forthcoming christmas, now wheres my beer barrels :lol: :lol: ...... 8-)
Re: TS1 bore wear
Posted: Fri Dec 19, 2014 8:40 am
by drunkmunkey6969
TS1-200 wrote:Decided to have look at my 230 TS1, as it has been in for 5 years and done a few miles, motor was running fine, found this amongst other things,the nicasil has worn off around the exhaust port, is this usual wear, I reckon about 9000 mls, rings were worn as well.most of these miles were without a filter.
'5 years, 9000 miles and running fine'......that's nice. Simply get it re-nicasil lined and off you go for another 5 years! :)
Re: TS1 bore wear
Posted: Fri Dec 19, 2014 4:49 pm
by tea5ive
get an iron liner put in , best of both ;)
