Project Li 125 series 2
Well those cases turned out very well indeed. Got to love that soda blasting.
Happy days.
Who does that down your way Kev?
kevspeed
Doom Patrol wrote:Happy days.
BLASTCOAT,UNIT 3 GREENMEADOW WORKS,PONTHIR RD,CAERLEON,NP18 3NY. 01633 430490 or 07939 825113 or [email protected]
kevspeed
Everything cleaned up beautifully,considering the crap that was on it!,all bearings have been replaced,and new nuts and washers fitted.
Shimming the gearbox was a doddle,the original shims were cleaned and re fitted as a guide,and would you believe it,they were all spot on and well within tolerance,so happy days :D ,everything turns as smooth as silk :D :D
:P
kevspeed
A lot more progress today,crankshaft fitted,sweet as a nut :D
Front sprocket/chain/guides/clutch,all in place :D (Bugger!,the picture never came out :x )
Crankcase cover fitted :D
Top end slid on without issue :D
Top dead centre found :D
And rest! :D :D
Good job mate keep the pictures coming :D
kevspeed
A bit of a break in the working schedule,but now back on track :)
Afew more parts fitted :D
Now for the big bit 8-)
Not as bad as they look :o
Image 8-)
kevspeed
Bolted a few more parts on to give the engine a try out!
3rd kick from dry!,sounds lovely 8-)
Possibility of a slight change of plan,it may now be going for the full resto a year early!,im just awaiting the final decision,and ill strip it right back to the base parts 8-)
DigDug
Nooo... Leave it as is far too good to restore. :o
Did you have to do that?
kevspeed
I would,but he's seen pictures of restored scooters,and is very keen on the 'as new' look,cant blame him really,there are some beautiful machines out there!
