Page 3 of 4
Re: A bit boggy - cold weather???
Posted: Sun Nov 16, 2014 1:13 am
by Yanker
Bufficus wrote:
Are you as pissed as I am?
Pissed? I AM RANTING. How fukin dare those Degos start sub-strating the Lambretts design with spade connectors and Vespugh stands and idiot lights and uuuugehthpf all that hideous Servetta ignition switch kockation and light switch butplug travesty?
Posted: Sun Nov 16, 2014 1:24 am
by Bufficus
Surely keeping the ignition switch up at high level will keep it dry?
Posted: Sun Nov 16, 2014 10:19 am
by mick1
alanscottj wrote:I'm actually thinking it might just be a power issue, not jetting, been out again and it just feels like its losing power at full throttle. I have a feeling I might have too many toys on it for the power it produces. For example, I have just fitted a SIP electronic speedo, the bike already had a EGT gauge that is back lit, I have had one of those 'mod' chargers on it for ages (but not actually charging anything, but still connected). So, maybe, just maybe I am using too much power. I have also just read on here that I need to change the spark plug to one that suits the SIP speedo, a resistor type plug. All of this combined may well be why I'm losing power top end???
In line with the other posts maybe you should fit a "Barometer" as well.....
I agree the power and ignition side are completely separate and the gadgets should not affect the ignition.
Stuck rings may also be a cause for the lack of power.
Posted: Sun Nov 16, 2014 10:33 am
by Timbo
Have you done anything to the carb or filter since the dyno no matter how little?
Posted: Sun Nov 16, 2014 10:53 am
by storkfoot
Have a look at the air/fuel graph on your dyno printout. It may be that Readspeed left the jetting at the top end a tad rich. Then, when you get the really damp air that we have had in the last few days, it is making it too rich.
Posted: Sun Nov 16, 2014 12:07 pm
by drunkmunkey6969
Yanker wrote:...... S.I.P.(WHATEVERT THAT STANDS FOR)?
Scooter Innovation Parts.
Posted: Sun Nov 16, 2014 12:40 pm
by bristolmod
fuel flow? sufficient?
Chris
Posted: Sun Nov 16, 2014 4:13 pm
by alanscottj
Timbo wrote:Have you done anything to the carb or filter since the dyno no matter how little?
Nope, haven't touched it
Posted: Sun Nov 16, 2014 4:14 pm
by alanscottj
storkfoot wrote:Have a look at the air/fuel graph on your dyno printout. It may be that Readspeed left the jetting at the top end a tad rich. Then, when you get the really damp air that we have had in the last few days, it is making it too rich.
https://fbcdn-sphotos-g-a.akamaihd.net/ ... 5ed463294f
Posted: Sun Nov 16, 2014 4:21 pm
by Marty ULC
Carb icing?
