Re: Vespa PX Exhaust Dilema
Posted: Thu Oct 02, 2014 9:48 pm
Oliver is a great guy very easy to do business with.
My exhaust arrived today and is exactly what I wanted, unfortunately it doesn't fit straight onto my scooter. I knew there would be modifications needed to the battery side panel, but I will need to modify the bracket that clamps onto the engine, hopefully won't need to do anything to the exhaust.
if I do need to extend the exhaust it will be on the small diameter section that connects the down pipe to the main exhaust chamber, it will be extended no more than 10-20mm in length are there any things I need to look out for when doing this. The reason for this is the exhaust hits the battery side of the chassis and the pipe looks like its going to foul the cables, Im hoping that a different bracket will sort out these problems.
Cheers Gary
Cheers Gary
