Lambretta sx 150 soft seize after 7 miles
garethwyn66
Main scooter: Vespa PX 125
Hi guys. Just an update as regards to what we found. Found the piston to be marked on the exhause side quite a heavy mark on it and also the oposite side of the piston and the barell was heavily polished were it had been picking up. The guy at scooter hub checked the ring gaps they were ok but a bit sticky in the piston grooves and also clearances between the barell and piston it s self was tighter than what he would have done on a rebore. Looks like it has had a few heat seizures before I bought it. So we went and fitted a standard italian new 150 cc barrel and piston. Now to run it in. Any comments on running in a top end are welcome. Been told 250 - 300 miles should be satisfactory.
Grumpy225
garethwyn66 wrote:Hi guys. Just an update as regards to what we found. Found the piston to be marked on the exhause side quite a heavy mark on it and also the oposite side of the piston and the barell was heavily polished were it had been picking up. The guy at scooter hub checked the ring gaps they were ok but a bit sticky in the piston grooves and also clearances between the barell and piston it s self was tighter than what he would have done on a rebore. Looks like it has had a few heat seizures before I bought it. So we went and fitted a standard italian new 150 cc barrel and piston. Now to run it in. Any comments on running in a top end are welcome. Been told 250 - 300 miles should be satisfactory.
Almost sounds like it was put together dirty or sucked some grime in along the way.
Use the search option re running in you will get many answers choose the one that suits you personally I rn mine in in stages up to 1000 MILES
