Page 3 of 3
Re: HELP! Lambretta Gearbox noise
Posted: Thu Jul 24, 2014 7:47 pm
by The Hiwatts
We have come to the conclusion after 14 gearbox/clutch rebuilds it's time to give in!!!
We are no further forward with it from the first rebuild!!!
I have put back in my original 150pacemaker engine and taken out the rebuilt 200, and will have to give it another go at a later day!!!!
Oh well!!!! Any ideas or suggestions apart from selling it off or burning would be welcome!!!!
Enough is enough
Thanks for the input and comments so far - top guys!!!
Posted: Thu Jul 24, 2014 8:32 pm
by fritz
[quote="wack 63"]Sliding dogs catching gears when in neutral?
good shout by wack 63 did you change sliding dog?
same problem cost me tooth off first gear and cluster
see wanted section
Posted: Wed Jul 30, 2014 7:52 pm
by HxPaul
dapper wrote:Also check that end plate studs/bolts aren't catching on the inside of the rear sprocket. Oh, and when you've sorted it post what was the eventual problem
It could be the chain hitting the end plate studs or layshaft bearing race,if the crown wheel shim is to thin or non existant.
Posted: Sat Aug 02, 2014 4:29 pm
by brianc
hi everyone,i ve got exactly the same problem,toataly re-built new everything gp175 in a series 2 case,i didn't worry about it too much till now,i was thinking it was just the chain as mentioned earlier,but now I don't know,
brian.
Posted: Wed Aug 13, 2014 4:44 pm
by bazza3004
bottom chain guide catching rear sprocket ?
Posted: Fri Aug 29, 2014 4:13 pm
by brianc
just took the chaincase cover off mine,turns out the clutch top steel plate has been rubbing on something,think its the inside of the kickstart,
brian.
Posted: Mon Sep 01, 2014 2:57 pm
by brianc
had another look at mine and its definitely the kickstart shaft wearing away the clutch top metal plate,looks like the kickshaft shaft is over cast,so I took off some metal with the angle grinder,
brian.
Posted: Sun Sep 28, 2014 1:44 pm
by brianc
everything back together again,noise still their,goes away as soon as clutch pulled,
brian.
