Any Ideas?
Special X
Your choke is sticking on - its a regular problem with the PHBH, that's why its the same choke on or off. loosen the cable right off and stretch the spring a bit and try it. If that cures it change to an AV266/X13 before you blow it up.
Agreed
ForemanBob
Main scooter: GP RT230
Special X wrote:Your choke is sticking on - its a regular problem with the PHBH, that's why its the same choke on or off. loosen the cable right off and stretch the spring a bit and try it. If that cures it change to an AV266/X13 before you blow it up.
No mate.... it was the stator.... Exactly the same with a PWK 30mm carb....
warts
Main scooter: honda
For people suffering the crappy choke on PHB's/DelOrtos in general. My bike has PHF?? but they all have the same choke system AFAIK.
I doubled up the springs, just wound another spring up in there. Worked a treat.
Special X
Sorry = I was fooled by the massive fuel stand off on the video clip.
    Users browsing this forum: Google Adsense [Bot] and 1 guest
