Page 3 of 3
Re: timing in degrees WTF ?
Posted: Sun Mar 30, 2014 10:57 pm
by Trojan
eden wrote::roll: Carlos aka non believer 8-)
all im gona say here is...........
P2+R2-2 RP cos(q) = L2 (Law of Cosines)
So P = R cos(q) + (L2 - R2 sin (q)2) 1/2
simples............ maybe not :lol:
:o :o :o Eden, WTF ,its Sunday just got in after a session on the beer, the clocks have gone forward , me heads battered, and now im reading this LOL, is nt it great that we can take the p*SS and learn at the same time,mmmmm time for another beer methinks.... :lol: ..... 8-)
Posted: Sun Mar 30, 2014 11:19 pm
by carlos fandango
yes, but can you explanation it in english.
Ok just did a few calcs .....so 110 rod 60mm stroke. big end 90 deg to bore .
if i rotate the crank 20 deg towards tdc the piston travels 19.54 mm
if i rotate the crank 20 deg towards bdc the piston travels 16.86 mm
:? its the devils work i say :D
Posted: Sun Mar 30, 2014 11:35 pm
by eden
lol:)
don't need to understand why,we just need to know its just the way it is.
chuck the timing disk and just use the calculators, its far easier and more accurate.
Posted: Sun Mar 30, 2014 11:50 pm
by Muppet
x is centa line; R half stroke 30mm; L rod 110mm; wen crank spins past 90 degrees the angle tween L and R is obtuse; cus top end of L moves on a fixed centa line X; wen the bottom end of L is connected to R; crank rotation creates different r to l angles; 'see the picture in y minds eye'
Posted: Mon Mar 31, 2014 6:34 am
by rosscla
That's the one...
Posted: Tue Apr 01, 2014 12:34 am
by sideout
Draw the cosine graph, degrees 0 to 360 on the X axis, 0 to max stroke on the Y axis. See how many degrees = Max stroke/2.
If TDC is at 0 degrees.
It's late and now April Fools Day. Disclaimer (C)
