Page 3 of 3
Re: Taffspeed Mk4 vs chiselspeeds ADS?
Posted: Fri Sep 16, 2016 9:56 pm
by mawso
Thanks for both replies :) Reeded Mugello 230 cool!
Mine's a version 1 barrel I bought it instead of a Rapido classic 225 barrel I had gone in for, has a widened inlet and opened up Atomic reed manifold, cut in boost port and piston windows on Suzuki piston, widened exhaust and cleaned transfers. 186 exhaust port now. Hope to get around same power as Camel. My pal's MB touring tune TS1, SX gearbox, 34 Dellorto and Taffspeed MK4 has been our benchmark club fast tourer for years...get it on a long run and it's shows it's legs and gradually leaves everybody way behind...and he's only doing 7k revs! So ADS3 has to be a better bet for taller gearing and grunt. You run a clubman!!! How does it compare to ADS3 for torque? I've an RS44 clubman but it's LOUD, sounds like a gattling gun, no power band but builds and builds and revved on to 8.5K.
4.6 with what gearbox? I can go same as Camel's I've LI125S engine in a box, so guessing gearbox will be same and can tinker with sprockets/crown wheel. 23lbs of torque is brilliant.
