Page 3 of 4
Re: Quattrini Build....
Posted: Tue Dec 23, 2014 5:11 pm
by sean brady scooters
ok mate .
Posted: Wed Dec 24, 2014 2:46 pm
by drunkmunkey6969
Our last Dyno before we close for Christmas!
A lovely result 19bhp @ only 6000rpm, and 17.5ft-lbs @ only 5500rpm. Power starts at just after 3000rpm, peaks at 6000rpm, and revs on past 7000rpm.......nice spread. A great touring setup, this will be a pleasure to ride!
Fancy more power & speed? Just change the pipe for something more sporty and watch the revs and BHP rise!
Merry Xmas everyone
Posted: Wed Dec 24, 2014 2:58 pm
by ipman
which exhaust would you suggest?
Posted: Wed Dec 24, 2014 3:08 pm
by drunkmunkey6969
For more peak BHP and revs? PipeDesign.de
Posted: Fri Dec 26, 2014 4:16 pm
thats a great result especially if you compare the torque graph to say a TS 1 !,and from only a 172 vespa !
Posted: Fri Dec 26, 2014 7:40 pm
by giankx
The best results in terms of peak and spread of power can be achieved with the Quattrini pipe. Trust me.
Posted: Wed Dec 31, 2014 3:41 pm
by cartmel808
sean brady scooters wrote:thats a great result especially if you compare the torque graph to say a TS 1 !,and from only a 172 vespa !
It is a great result Sean & I'm very happy with it
.... but the child in me wants to explore further what it'll do with a different (revvier) pipe - so need to decide on either; one of Pipe Designs offerings - or the dedicated Quattrini pipe..... and then possibly a 60mm crank & 35mm carb aswell
Posted: Wed Dec 31, 2014 5:00 pm
by bazman
What's it like on the road, as in power delivery , a kick up the pants or more gentle !!?
Posted: Fri Jan 02, 2015 3:31 pm
giankx wrote:The best results in terms of peak and spread of power can be achieved with the Quattrini pipe. Trust me.
dont suppose you have a dyno graph for one of these pipes for comparison ?
Posted: Fri Jan 02, 2015 5:35 pm
cartmel808 wrote:sean brady scooters wrote:thats a great result especially if you compare the torque graph to say a TS 1 !,and from only a 172 vespa !
try another pipe first graham ,as its the easist option to attain more revs and bhp and speed on the gearing you have in it ,torque would drop a bit but you have more than enough anyways .
I dont think much gains are to be had from a bigger carb on this if any tbh .
nor the 60mm crank ,bearing in mind the cost etc ..the longer stroke will in fact inhibit it spinning up as readily and only add more torque
