Page 3 of 5
Re: It's cheaper this way ...
Posted: Thu Mar 06, 2014 8:12 pm
by storkfoot
Yes, Col, the Nitrous Oxide switch and Flux Capacitor will sit quite nicely on the top, I do believe :)
Posted: Thu Mar 06, 2014 11:30 pm
by coaster
storkfoot wrote:Yes, Col, the Nitrous Oxide switch and Flux Capacitor will sit quite nicely on the top, I do believe :)
:lol: :lol:
Posted: Tue Mar 18, 2014 10:34 pm
by storkfoot
Leggies on, legshield toolbox dry fitted but still need to dry fit dual tanks. Hopefully, this weekend :D
Posted: Tue Mar 18, 2014 11:12 pm
by rosscla
Coming together nicely.
Posted: Mon Mar 24, 2014 9:56 pm
by storkfoot
A bit of mild panic this weekend when I thought the carb was going to foul the toolbox, however, I was just being daft. It doesn't :D
Anyway, by way of update, I've set the reverse pull with a longish cable (it's the thicker Scooter Restorations front cable) to allow easy wheel changing. Whether this will have a slightly adverse effect on braking, I'll have to wait and see.
Carb filter wise, I'm trying one of the MB ones. The Gran turismo manifold is slightly downdraught which, as you can just about see, means the filter presses against the panel at the bottom but not at the top. The remedy to this is to stick the filter on the panel. This is not what I wanted as it then makes the filter a bit of a pain to clean but I'll be very interested to see whether this works well. Or not :)
Posted: Mon Mar 24, 2014 10:09 pm
by coaster
You've got plenty of room for a bellows and a remote there Paul, I went that way with the TS1 and it fits a treat under the LiS panel, runs a treat too now 8-)
Posted: Mon Mar 24, 2014 11:36 pm
by slangen
Is that a phbl25?
Posted: Mon Mar 24, 2014 11:44 pm
by storkfoot
It's a PHBH 30.
Col, the original plan was a camlam breath sweet, however, I thought I'd give the MB filter a go first. Out of interest really.
Posted: Tue Mar 25, 2014 12:55 am
by coaster
storkfoot wrote:It's a PHBH 30.
How does it attach to the carb as a matter of interest :?:
Posted: Tue Mar 25, 2014 10:09 pm
by storkfoot
The bellmouth on a PHBH has a bit of a lip on it. The hole of the filter is a bit smaller diameter that the external diameter of the bellmouth, and so, it stretches over it and the lip keeps it in place.
Glued to the panel will, in my case, result in the bottom of the bellmouth sitting comfortably inside the filter and the top just sitting inside.
