Page 3 of 3
Re: Lambretta Series 2 with Megasquirt EFI and 180w Igntion
Posted: Wed Apr 15, 2015 9:30 pm
by Rich_T
WINTERMODEL150 wrote:
Hi Rich.what sort of fuel pressure would you estimate these to run at?how is the cold start enrichment device worked out if its air cooled?is there a sensor under spark plug or in exhaust?do you run a stepper motor for the idle or just a cable effect?.
Regards
Dean
There is an air temp sensor and cylinder temp sensor. No stepper for idle.
Posted: Thu Apr 16, 2015 11:47 am
by WINTERMODEL150
Rich_T wrote:WINTERMODEL150 wrote:
Hi Rich.what sort of fuel pressure would you estimate these to run at?how is stalling runart enrichment device worked out if its air cooled?is there a sensor under spark plug or in exhaust?do you run a stepper motor for the idle or just a cable effect?.
Regards
Dean
I guess if you're not using a choke from cold anymore they'll be some kind of fuel enrichment device to stop the bike stalling from cold?
