Page 3 of 5
Re: New SIL engine or build from empty casing?
Posted: Sat Jan 11, 2014 1:50 pm
by corrado
My take was how much will it cost to build an engine from scratch with parts that improve the parts you'd ditch from a complete SIL engine or parts that you'd need to buy that are an improvement, ie, the engine mounts and the crank you listed, but without going overboard on exotic parts like 7 plate clutches and 5 speed gearboxes, etc.
Posted: Sat Jan 11, 2014 1:55 pm
by corrado
Quality rear hub bearing / seal. MB or RIV £35.00
Running total £435
Posted: Sat Jan 11, 2014 5:56 pm
by wurzel
Scooter Restorations
SIL GP 200 gearbox £120
Running total £555
Posted: Sat Jan 11, 2014 8:04 pm
by tavspeed
http://www.ebay.co.uk/itm/Reworked-Lamb ... 27dca92f81
fettled alloy 225 kit, £169
total now £724
Posted: Sun Jan 12, 2014 1:04 am
by rosscla
Layshaft, restos
£39.95
Running Total : £763.95
Posted: Sun Jan 12, 2014 9:37 am
by speedy
Before we get ahead of ourselves here boys, one question? Have we got a full and/or useful tool kit to do the job in hand? Because if not, ching ching, and there's no way anybodys borrowing my plug spanner before we bloody well start, as I never got me last one back! :lol:
Posted: Sun Jan 12, 2014 10:21 am
by slangen
rosscla wrote:Layshaft, restos
£39.95
What's the general opinion on these layshafts, any good for 30hp+ engines? Any other options except for the MB?
Posted: Sun Jan 12, 2014 11:20 am
by tavspeed
these prices are off the top of my head.
mag flange £30
engine bearing set £70
gasket set £7
cylinder studs, nuts etc £!0
inlet and exhaust studs £8
stator plate and flywheel indian £100
stator plate wire clamp £3
mag flange sealing plates £4
6mm nuts and magflange circlip £3
seal kit £12
seal retainer plate and csk screws mb £15
above comes to £252 and should complete top end total now is £1027.95
Posted: Sun Jan 12, 2014 12:34 pm
by corrado
Rules :
Choose one part - must be available
Post the price
Post the source
Update the running total
Rules is Rules. ;)
Posted: Sun Jan 12, 2014 5:32 pm
by joespeed
joespeed wrote:the crankshaft bearing is suspect but will do short none thrash for quite some time,it is far cheaper to buy the stock indian 200cc engine and improve it by putting in a new crank or just a rod kit ,new main and mag bearings,chain and nylon style tensioners,this will be quite a good motor further improvements like rear hub bearing can be changed but is less critical,
buying loose components is not the cheapest way unless your building something quick with lots of special and uprated parts.
good cheap engine will cost around £1300 then after this the skies the limit!
i bet i'm close,i do note some prices quoted are cheaper than cheap and you should be taking an average price on these parts as some areas/shops may not be as cheap!!
