Page 3 of 5
Re: LD ish
Posted: Thu Jul 24, 2014 6:55 pm
by gerryjunior
thanks ..i like it .
Re: LD ish
Posted: Sat Jul 26, 2014 11:39 pm
by gerryjunior
I treated LDish to a bit of bling ,new JL pipe...
Re: LD ish
Posted: Sun Mar 15, 2015 10:27 pm
by gerryjunior
the front forks were very soft on this and would bottom out badly on braking, i searched ebay and found a rear moped shock that was almost the same length as the late indian style one , so i ordered two and with a little modification the fitted and are working a treat,,
Re: LD ish
Posted: Sun Mar 15, 2015 10:37 pm
by gerryjunior
Re: LD ish
Posted: Sun Mar 15, 2015 10:41 pm
by gerryjunior
had to trim the panel to fit over the carb and fitted a low fuel warning light, think ill need it.
Re: LD ish
Posted: Sat Apr 04, 2015 9:13 pm
by gerryjunior
fitted an LD toolbox today, and a sip digital speedo, got tired of guessing my speed,
Re: LD ish
Posted: Sat Apr 04, 2015 10:23 pm
by B-Race Tuning
Gerry, I love that. Do you know the origin of the 240? It looks familiar. Lovely kits set up well, vibrate mind
S
Re: LD ish
Posted: Sun Apr 05, 2015 11:24 am
by gerryjunior
240 was an ebay purchase, you may well know it, its stamped mrb and a number, dosent vibrate too bad , but not fully sorted yet its not pulling as well in 4th as id like so im going to change my gearing and re check the timing etc, great to start and first 3 gears are fine , dosent die in 4th just feels a bit flat , ill know better with a speedo.
Re: LD ish
Posted: Sun Apr 12, 2015 4:42 pm
by gerryjunior
Re: LD ish
Posted: Sat Aug 08, 2015 5:19 pm
by gerryjunior
well the gearing was the problem on the 240 , it turned out to be an indian 150 box and not a 200 as id been told.. the front forks are still bottoming out when i brake hard so im going to have to figure out some kind of anti dive for the forks. . has anyone done this on late style indian forks , a pic would be nice.. and i need to sort some storage for my 2 stroke , the ld toolbox just isn't big enough.
