Page 3 of 4
Re: carb needles...........and the common prob of weak mixtures
Posted: Sat May 16, 2009 8:56 am
by Special X
Have you tried
52 idle
AV266 atomiser
X13 needle
118/120 main
That should be somewhere near if you haven't got an air leak or a problem with the choke plunger (very common) You need plenty of play in the cable and to ensure that the spring is pushing the plunger home.
Posted: Sat May 16, 2009 8:19 pm
by drunkmunkey6969
what problems are you actually having?
Posted: Sat May 16, 2009 9:41 pm
by RBG
Talking about 5000 rpm & Needles.
I was going to post my findings & pick your brains.
But there's a post going. :)
I fitted an EGT & Rev counter before setting off for Spain.
RB22 35mm Mikuni with filter, full panelled
320 main
22.5 pilot
57 needle 2nd clip.
18deg
AF close ratio gearbox & 19 x 46
Franspeed tourer.
My main concern was travelling at the 5000rpm mark
cased of constantly speeding up & slowing down & bringing the main jet on line.
This I found strange as the Scoot just ticks over fine & before fitting the EGT this is where I would sit as I plodded along.
The scoot will not rev much past 7000rpm & the EGT reads 475-500 at 6000+rpm
At 5000rpm it can get up to 650+C.
I can keep it below 600C.
What will at franspeed tourer rev out at & what's the ratio of this gear box.
I don't think my speedo is too far out for a Lambretta at 6000rpm it says I'm doing 70mph.
Flat out is off the clock & shockingly fast on 10' wheels.
Do you think dropping down to the 3rd clip on the needle will help any?
Posted: Sat May 16, 2009 10:03 pm
by DaveInPortland
drunkmunkey6969 wrote:what problems are you actually having?
I have a dual EGT/CHT gauge installed as well as a rev counter (tachometer). My exhaust gas temps spike to 1200F in the 25%-50% throttle range, indicating it is leaning out.
The only atomizers I have tried are the 264 and 266 with the X4 and X7 needles.
Can these PHBH carbs be dialed in reliably or should I dump it for something else? I don't want to continually fight this thing.
Posted: Sat May 16, 2009 10:21 pm
by drunkmunkey6969
DaveInPortland wrote: I have a dual EGT/CHT gauge installed as well as a rev counter (tachometer). My exhaust gas temps spike to 1200F in the 25%-50% throttle range, indicating it is leaning out.
What pilot jet and what slide are you running?
Posted: Sat May 16, 2009 10:32 pm
by drunkmunkey6969
RBG.....crikey.....one question at a time please mate! :D
So.....to clarify:
1) Your RB doesnt rev over 7000rpm?
2) At 5000rpm the heat spikes from 475 upto 650+ (what part of throttle are you on here?)
3) You want to know what a franspeed tourer will rev out to
4) What is the final drive ratio of and AF close ratio gearbox on 19/46
5) Will dropping down to the 3rd clip on the needle will help?
Am i correct on what you are saying and what you want to know?
Posted: Sat May 16, 2009 10:36 pm
by sean brady scooters
just generalizing here of course..........
but if your EGT,CHT guages are telling you that your motor is overheating at a certain rev range....................
it does not always equate to the fact that it may be a carb prob and too lean..................
consider also that its just not cooling efficiently enough at those typically 4th gear low speeds.............
the choice of gearing can effect cooling..............
Posted: Sat May 16, 2009 10:48 pm
by RBG
drunkmunkey6969 wrote:RBG.....crikey.....one question at a time please mate! :D
So.....to clarify:
Yes mate.
1. yep 7K is about the lot. "I have a feeling that it could be the CDI" but not knowing the limit of the exhaust.
2. 1/3-1/2 throttle. Bliping the throttle brings the temp down.
3,
4. 4.8???
5. please :lol:
Other than the 5000rpm temp shocker she's running well.
Thanks.
Posted: Sun May 17, 2009 6:02 pm
by Bufficus
RBG wrote: Yes mate.
My Franspped Tourer would rev to 8000rpm according to my Pitsch Krober rev counter.
Posted: Sun May 17, 2009 6:07 pm
by DaveInPortland
I split my inquiry off to it's own topic. We have a few different conversations going on here and it's going to get confusing.
http://scooterotica.org/forum/viewtopic.php?f=7&t=2928
