Page 3 of 3
Re: Remote problems....will a dyno sort it...?
Posted: Sat Jul 20, 2013 2:10 am
by corrado
PHBH 26 on stg 4 Indian 200 [the shitty 3 ringer] with AF 42mm clubman.
Was given this by someone who knows a lot more about carbs than I know.
Idle 52/55
Atomiser AV266 with X7/X13 needle (X13 is richer)
If too rich with AV266/X13 but too weak with Av266/X7 use AV264/X13 all on 2nd clip.
Main aprox 110 with breathsweet, 105/7 through airbox.
These should get you into the ballpark.
My mild tune 230 is running ok on 52 idle, AV266/X13, 110 main with ram air.
I'm using 52 idle, AV266, X13 needle, 110 main with breath sweet filter, 40 slide, 250 float valve. No fuel in carb elbow and great on juice, just not very fast.
