Page 3 of 6
Re: 12volt DC Mod charger
Posted: Mon Apr 01, 2013 11:55 am
by shocky
Knygall wrote:I'd priced up all the bgm parts.. Running Af's electic kit at min... Got price for bgm cdi , £20+ , but was under impression I'd need. Battery too???.....
YOU CAN USE ANY 12V BATTERY
dont just think standard motorcycle size a 12v remote control car battery pack is suitable and you can hide these anywere
or
http://www.ebay.co.uk/itm/VT12021-Seale ... 3ccf62369b
or
Posted: Mon Apr 01, 2013 12:10 pm
by firekdp
sideout wrote:Couldn't post a circuit diagram could you mate? It would be really interesting! You made it sound so simple
This should do it, may be worth experimenting with cap values though.
Posted: Mon Apr 01, 2013 6:04 pm
by rbgaz
i charge a 12volt m c battery from the bgm unit , which i have fixed behind the legsheild spare wheel carrier, it runs my led rear light, led rear brake,led speedo,park and two extra high viz leds in head lamp, the only powered item by ac is main headlamp, i also plug a sat nav in to the battery via a cig charger and also charge my phone at same time, also used to run a vapour speedo and egt gauge as well off the bgm unit but dont now as these have broke, ive never had to charge the battery from the mains
Posted: Mon Apr 01, 2013 9:24 pm
by sideout
firekdp wrote:sideout wrote:Couldn't post a circuit diagram could you mate? It would be really interesting! You made it sound so simple
....snip
Thanks very much, I've got a rectifier, I'll have a play!
Nigel
Posted: Mon Apr 01, 2013 9:27 pm
by sideout
rbgaz wrote:.... also used to run a vapour speedo and egt gauge as well off the bgm unit but dont now as these have broke...
Hmm, hope it wasn't down to the BGM unit
Posted: Tue Apr 02, 2013 7:34 am
by rbgaz
lol no, the vapour got water in it and the koso cht lead broke
Posted: Thu Apr 11, 2013 4:36 pm
by ktmh5
I have fitted these Modchargers to two of my scooters now. What an amazing and ingenious piece of kit, well impressed and only take a couple of minutes to fit.
Posted: Thu May 09, 2013 5:12 pm
by a.j
I've just bought one...well I got two actually. A feckin' Godsend in my opinion..
Posted: Fri May 10, 2013 6:00 pm
by shep
I've recently fitted pathfinders on my scooter that I was going to wire up to an independent battery (my scoots AC) that I could re charge when necessary, could one of these be used to charge the battery as I go along?
Cheers.
Posted: Fri May 10, 2013 8:55 pm
by bizzly
I think it only kicks out about 1 or 2 amp....dont think that would be enough to charge a battery. I know it wont work my tyre pumper upper that works via cigar socket
