Re: is there any reason why......
Posted: Mon Feb 11, 2013 10:48 pm
will be going with inlet to the rear, the reason being if the the cylinder was reversed this would restrict the exhaust fitmentRICSPEED wrote:so ..why not stick with your first plan and have the carb forwards .. ill bet that manifild as it is would curve its way round the frame nicely .. pipe out the back ..and i know a pipe fab guy near me .. bang on .. so
do you intend to fit an adaptor plate or weld up ?? how does the j motor compare stroke wise to a smallie motor ??
i have altered the inlet manifold to fit and now gives good clearance.
photo sharing websites
pic upload
online photo sharing
the starstream crank is 48mm stroke/95mm rod. ideal set up for the parmakit is 51mm stroke/105mm rod. drt do a rod with the same dimensions as the starstream baring the big end pin which is 20mm and of course rod length (105mm), starstream being 18mm big end pin. drt also do an eccentric pin to go with the 105mm rod which gives you + or - 2mm , so with the ends ground down to 18mm and fitted in the starstream crank this would give me 50mm stroke/ 105mm rod (drt rod + eccentric pin) this gets me right in the ball park.
a packer plate of 9mm to 10mm (alowing for base gasket of 1/2 to 1 mm) ,pre drilled with the parma stud spacing and transfers to match with a small spigot to go from the starstream case to the parma cylinder will be welded to the case. no point welding the case . just weld the packer to the case, even if i want to reverse the cylinder after the packer is welded on i still can as the stud and transfers are symetrical through 180deg
what do you think
