Page 3 of 4
Re: Big jigsaw ( moving thread to here ).. 62 li series 3
Posted: Sat Dec 07, 2013 1:52 pm
by Junglemod
Here you go a few more recent pics
Got it back from painters and in the meantime made myself a bike lift to put al back together on had the alli plate in the garage from some floor work in the house 12 years ago ( hoarder ) so that came in handy too .
Got a rack to keep new bits on
Started. Assembly of a few bits
This is the most recent still a lot to do
Motor is away at dai Paynes .. On small wheels getting a little cc increase .
Cheers Steve
Posted: Sat Dec 07, 2013 1:53 pm
by Junglemod
Have made a mistake in putting wrong cable to motor !!! Front brake instead of clutch
Posted: Mon Dec 16, 2013 11:31 am
by Junglemod
Not the best pic but casing back from polishing
Posted: Fri Dec 20, 2013 6:49 pm
by Toddy
Polishing looks good was it expensive ?
Posted: Fri Dec 20, 2013 8:59 pm
by Junglemod
Hi
Compared to the cost of getting it chromed I recon it was a good deal ,all in £250 , a fella in Birmingham . I'm not worried about a little elbow grease to keep it tidy . Will post another pic once its all back together .
Cheers Steve
Posted: Sun Jan 19, 2014 9:56 pm
by servetapaul
Have you picked up on the quirky bits that make a 62 slightly different from the later Li's ?
Posted: Tue Jan 21, 2014 9:00 pm
by Junglemod
servetapaul wrote:Have you picked up on the quirky bits that make a 62 slightly different from the later Li's ?
Hi
I've had a few things I've scratched my head with on the refit ,and being over 18 years since the strip down ,nowt left upstairs to prompt me .
Can you give me a few tips on what else I'm likely to come across ? Still waiting on the motor to get the back end up off its prop
Cheers Steve
Posted: Wed Jan 22, 2014 9:51 am
by servetapaul
It's only a few things and most won't matter too much
The forks have a wire loop cable holder as on the series 2
The frame loop arch where the bridge piece goes is a simple arch as per series 2 - the later ones have an extra bit cut out where the choke goes
The bridge piece is different ( I think )
The engine will have the series 2 type 'cush drive' sprocket and 4 pole electrics and flywheel
And they would have had the early single seats where the front in different to the back ( no wedge packer)
Almost everyone thinks Li's are all the same
Posted: Wed Jan 22, 2014 9:53 am
by servetapaul
Did you add the battery tray ?
Posted: Sat Jan 25, 2014 9:53 am
by Junglemod
Hi Paul
Got the wire loop on the forks ,
The rest I'd not noticed .
Battery tray was on it when I got it , welding looks factory ?
Was that not an option in 62 ?
Was thinking of putting the twin seats back on but opted for a standard seat .
Cheers for the info
