Page 3 of 7
Re: Handlebar choke kit /cooling/tuning aid/engine sa
Posted: Sat Feb 02, 2013 1:26 am
by Darrell Taylor
wack 63 wrote:The one I made is on the DKS grp 4 bike with Delly VHSB ,cable loosely run down frame and dropping down to carb like the throttle cable. Mates isn't fitted yet but will be on TMX 35. Prior to spring fitted
oh so its not tried/fitted yet? let us know how u get on
got them on delly 30 / mik 35 and pwk 38 and all working well
Posted: Sat Feb 02, 2013 10:59 pm
by wack 63
No, not tested yet.My thought was to get it on the dyno and maybe play around with the choke jet sizes before Mallory test day. One other thing that may cause problems is cold starting a road scoot and having to keep the lever pressed whilst warming the scoot up so I've toyed with trying to use a cable splitter therefore keeping the standard choke as well.
Posted: Sat Feb 02, 2013 11:35 pm
by Darrell Taylor
ive found the opposite its easier for cold starting as normally its choke on then start cold motor then it stalls so reach down and turn off and start again , if pilot is big enough and mixture screw set right choke only needs to be on for a few seconds to initially start then release choke which is easily done with one hand on the throttle , lean pilots and over advanced ignition will cause difficult starting
Posted: Sun Feb 03, 2013 10:24 pm
by Gazjet1
Darrell, do have any of these kits left & if so could you let me know how I can get one off you. Cheers
Posted: Sun Feb 03, 2013 10:32 pm
by Gazjet1
Darrell, have you any of these kits left and if so how do I get one from you? Cheers
Posted: Mon Feb 04, 2013 1:57 pm
by Darrell Taylor
had some nice feedback below from giancarlo (giankx on here) who ordered 2 kits for his scoots and fitted them
Received today and fitted. Really easy, everything FITS, without fettling or cutting. No bodging required. I didn't need to remove my horncast, the cable was routed under a small hole into the lower part of the headset and down into the fork. Thank you Darrell, money well spent!
Posted: Mon Feb 04, 2013 10:17 pm
by giankx
Confirm everything, on my TMX 35 and VHSH 30mm the choke spring is hard enough to let lever fully return.
Just a tip, i've filed some allory from the lower part of the lever, where the bolt fits. This allow the bolt tu fully screw into the bracket so now the lever is moving freely without losing the bolt with its movement.
Posted: Mon Feb 04, 2013 10:44 pm
by Darrell Taylor
thanks again for feedback,
having checked thru the various kits ive found that a handful have a pinch bolt on the lever that when fully tightened down or overtightened will give resistance but found when i moved the lever back and forth around 20 times it freed up,despite this ive machined down a handful of tight levers as well as drilling cable holes to ease fitment
any pics please Giancarlo
Posted: Tue Feb 05, 2013 12:16 am
by Darrell Taylor
cheers eden,that be good to see, do you have egt or a cyl head temp gauge ?
Posted: Fri Feb 08, 2013 2:14 pm
by giankx
Some pics of the choke kit fitted to my Lambrettas:
