Stator Plate problem
Muppet
Eden wrote:
And the pick up.
Is the fkywheel rubbing in the puck up?
You will know because the end of it will have ware marks.
Can happen due to a twisted crank or f@@ked bearings
^wot he said^
C’est la vie
firekdp
coaster wrote:Were those reasdings all to earth? they seem way too low. Red (pickup) to earth needs to be between 95 to 100 ohms
Green (LT coil) needs to be 450 to 500ish ohms
Eden wrote:And the pick up.
It's a varitronic????
Although varying a fair bit with the temp, your coil readings are still within the spec given.
You have disconnected the ignition cut out wire to discount that being the problem?
dopeshots
Xbox live gamer tag: rms789
Main scooter: GP150
Yes it is a varitronic ignition.... sorry for being thick but which wire is the cut out wire, Is that the red/blk that goes to the coil?
Muppet
Nah; I think y nailed it with "fkywheel rubbing the puck up?
C’est la vie
Muppet
Eden wrote:lol,
this could be the reason though....
In'it supposed t be spelt Virtualironic????
C’est la vie
firekdp
dopeshots wrote:sorry for being thick but which wire is the cut out wire, Is that the red/blk that goes to the coil?
No it's the loom green, this joins to the red/black at the CDI.
tea5ive
Main scooter: cometa 140
to check if the flywheel is rubbing get a marker pen and cover the pick ups with ink. re fit flywheel and fire up the motor, if yo have a wibily woberly crank then you will see where its been catching.. have you tryied a different flywheel ?, has your flywheel been beefed up i.e welded up boss and have you lapped the flywheel onto the crank with a bit of grinding paste ?. has the weight band moved ?. i hope you/we get to the bottom of this. stick with it ;)
dopeshots
Main scooter: GP150
Quick update and another question please.
I was checking for movement in the flywheel to see if when I turned the engine over that the flywheel ran true and to the naked eye with the flywheel still tightened it appears that it is ok, however I grabed the fins of the flywheel and noticed that if I pulled the flywheel from side to side I could feel a very slight movement in the bearing, at least that's how it feels to me. It's not much movement but I do not know if there should be any at all.
So that's the next question... Should there be any lateral movement in the bearing?
Russ :fb:
dopeshots
Main scooter: GP150
Thought I'd update this thread...
After finding bothe the mag side bearing and drive side bearing were worn. I stripped the engine and rebuilt it. Feeling very chuffed with myself I have been riding it about for a few miles and it seemed ok, that was until today when it started playing up again and misfiring.
I did the normal thing and changed the plug and it then ran fine?
Any other ideas most welcome.....
Russ :fb:
weedodger
Main scooter: Indian gp casa 185 and 200
have you taken the green wire out of the cdi unit? then run it, if it runs fine, it will be your ignition wiring in the headset,put the green back in, run it and see if it still misfires? iv just had similar problems wi my casa 185. i thought it was the stator, but if it starts and runs etc, i think you can discount the stator, as your readings are fine?
    Users browsing this forum: Amazon [Bot] and 6 guests
