Page 3 of 4
Re: help bike wont start
Posted: Sun Jan 06, 2013 4:18 pm
by cit205
Yes you need a new float ,although of course that won't affect spark but it will flood and not help starting.
To tell if it is an ignition switch fault pull the boot off the cdi and pull out the green wire nearest the outside out then try,if it sparks and runs then you have a fault in that wire which goes to the switch, or the switch.
Make sure the ht lead and cap is all good and secure both ends.
If no different then get another cdi off a mate and swap over ,that will tell you if it is the cdi.
You can't tell if a stator is good just from looking at it, as i said in that post above you could have a pick-up or LT coil failing.
Posted: Sun Jan 06, 2013 4:24 pm
by soulboy
i disconnected the green wire at the start to illimenate that ive checked plug cap and reconnected ht lead so as you say next thing is the cdi ...fingers crossed
Posted: Sun Jan 06, 2013 10:27 pm
by ducksta
still sounds like rings stuck in
Posted: Mon Jan 07, 2013 10:36 am
by soulboy
but theres is no spark at all now and its been miss firing on and off for a bit ..so ive ordered new cdi and a new float AND FELLAS THANKS AGAIN FOR ALL THE ADVICE CHEERS :fb:
Posted: Mon Jan 07, 2013 1:14 pm
by ArmandTanzarian
cit205 wrote:Yes you need a new float ,although of course that won't affect spark but it will flood and not help starting.
Change the word Vespa to Lambretta and you could be describing exactly what happened to me last year. I even had a float full of petrol. Eventually it turned out to be a the LT coil.
Posted: Mon Jan 07, 2013 2:42 pm
by GLscoot
My problem, I think is fixed. It was the switch and the HT Coil. I tried three HT Coils before I could get it to start and only after I removed the green wire from the coil. From now on I will have 3 replacement parts as one of the coils was brand new and knackered from the start.
Gary
Posted: Mon Jan 07, 2013 6:33 pm
by soulboy
i hope it aint the lt coil as ive got a new cdi comin tommorow :barfy:
Posted: Tue Jan 08, 2013 11:08 am
by GLscoot
Sorry, I ment three CDI Units. All three had spark but would not allow the scooter to start. I checked them all again after I replaced the switch and only one worked properly. From now on when I buy a spare/ back up part I am going to check it works straight away, especially electrical and carburettor parts.
This problem has caused me all sorts of problems. Especially as one of the CDI units was brand new and didn't work.
Gary
Posted: Tue Jan 08, 2013 11:36 am
by cit205
soulboy wrote:i hope it aint the lt coil as ive got a new cdi comin tommorow :barfy:
Ah well if so at least you'd have a spare CDI now for on the road :anbrgin;
Posted: Tue Jan 08, 2013 4:49 pm
by soulboy
C.D.I it was fellas all done now and as ive said thanks to all of ya top lads :fb: :fb: :bouncyeng:
