Whats A Good Spotlight to Fit?
servetakid
I would only plan to fit one. I have an LED rear light bulb. And the spot light would only be used ocassinally when needed, not perminantly.
rbgaz
i def recon trying the reedspeed bulb but change all other bulbs to leds and run leds of batt u be impressed
frank sanderson
here are a couple of pics of the ones I fitted to my SX all the wires are inside horncast just drill 2 holes in horncast ,couldnt bear to drill holes in my fairings,.Wired them up to sidelight bulb wiring so on seperately from main and dip . Idont have a battery but are very bright when revs are high . really needs a big out put stator like a BGM Im on normal type electronic.
rbgaz
thats nice scoot frank
Neat and practical
servetakid
Really like them spots, I already have holes in the horncasting area from indicator stalks. What male are they?
Thanks
Very neet fitment Frank but are you saying you get bright spots with the headlamp on? What size bulbs are you using?
servetakid wrote:I also was looking at these type of spots. http://www.ebay.co.uk/itm/A-Pair-Rally- ... 2a17d847a2
Cheap enought, any thoughts?
They're fog lights. Different beam pattern.
frank sanderson
the spots are driving lights Stainless steel the same as fitted to the new mini made by wipac so cost a bit will see what I can get them for .Bulbs are same as would be used on mini but as I said very bright when revs are high, for best results would suit a scoot with battery and electronic.
