Page 3 of 3
Re: Mugello an gearing advise
Posted: Tue Jan 01, 2013 3:50 pm
by Danger
Anybody no what jetting I should be using
Posted: Wed Jan 02, 2013 9:34 am
by Donnie
I'd start here, remember all jettings a guide, even machines with the same setup will require different jetting much of the time.
http://scooterotica.org/forum/viewforum.php?f=9
Posted: Fri Jan 11, 2013 12:02 am
by mark1
I run a muggy 186, JL3, 30mm PHBH transfers matched, 16 x 46 LI 150 box in it. no problems with it screeming, like has been said above check the clutch.
Posted: Sun Jan 13, 2013 11:28 pm
by Danger
Leaving gearbox as it is , have removed the AF lightend flywheel an I'm putting a standard one on I'm also resetting the timing to 14 degrees plus I've sent my 30mil delly off to cam lam to have it blue printed so to speak to suit my setup hopefully all will be well with it once I get all this done
