Page 3 of 5
Re: sip speedo working with wassel
Posted: Sat Jan 19, 2013 2:32 pm
by simonwwfc
Must say just took my time with it all used shrink wrap etc on wiring . fitted a br8es spark plug as well even though i fitted sensor to cowling just to be on safe side . just a few questions
will clock need setting every time i start scoot i dont have a batt on mine ?
Is it pretty straight forward setting ratio etc my front tyre is conti 3.50 - 10 m/c 59 j ?
do i need to change anything in settings as stayed with speedo cable Not sensor in the end ?
How do i get it to mph on clock ?
thanks simon to bloody cold outside to play
Posted: Sat Jan 19, 2013 2:49 pm
by sideout
simonwwfc wrote:Must say just took my time with it all used shrink wrap etc on wiring . fitted a br8es spark plug as well even though i fitted sensor to cowling just to be on safe side . just a few questions
will clock need setting every time i start scoot i dont have a batt on mine ? - No, it remembers at least until the internal battery discharges, a bit like your computer remembering the time.
Is it pretty straight forward setting ratio etc my front tyre is conti 3.50 - 10 m/c 59 j ? - Yes, [Setting 3] mine is set to 1287 (Bridgestone Hoop) with the speedo gear set to 0.78
do i need to change anything in settings as stayed with speedo cable Not sensor in the end ? - [Setting 2] set to INT for speedo cable
How do i get it to mph on clock ? - [Setting 1] Select F for miles and degrees F
Additionally, [Setting 4] is 3 for my BGM stator :)
Cheers,
Nigel
Posted: Sat Jan 19, 2013 3:39 pm
by simonwwfc
Thank you :fb:
Posted: Sat Jan 19, 2013 4:32 pm
by soulsurfer
That looks like a Goodridge? braided hose to me Eden ;-)
Posted: Sat Jan 19, 2013 4:34 pm
by soulsurfer
Yes
Posted: Sat Jan 19, 2013 4:41 pm
by Toddy
They are like the ones chiggy does with a coating over the metal hose I have one on my series 1 :D
Posted: Sat Jan 19, 2013 4:55 pm
by soulsurfer
We digress... :-)
Posted: Sat Jan 19, 2013 5:14 pm
by simonwwfc
yes its mine but goodridge braided hose
Posted: Mon Jan 21, 2013 2:15 pm
by simonwwfc
I've marked tyre and path did one full turn roughly 1325 ???
Also do I need to touch rpm pulse setting ?
Posted: Mon Jan 21, 2013 6:25 pm
by simonwwfc
Eden wrote:1325 sounds about right :)
leave rpm on the default setting 1st see if it works
Had a fiddle with settings in rpm and tried it on 1 it seems way out then on 2 , so left on default I think 3 . Now how do I work out other input to go with 1325 measurement .
