Page 3 of 15
Re: New Big Block Gran Turismo Kit 200-245cc
Posted: Mon Dec 24, 2012 2:00 am
by ricalnic
RICSPEED wrote:whats the lc barrel ??
I wondered that too, but didn't want to show my ignorance...now there's something, a production LC lambretta barrel....mmmmm..Santa!
Posted: Mon Dec 24, 2012 2:05 am
by RICSPEED
ricalnic wrote:RICSPEED wrote:whats the lc barrel ??
would need crank induction though
Posted: Mon Dec 24, 2012 9:44 am
by 10 inch Terror
RICSPEED wrote:ricalnic wrote:RICSPEED wrote:whats the lc barrel ??
Damn.
Posted: Mon Dec 24, 2012 10:37 am
by Avantone
Like a Vespa
Posted: Mon Dec 24, 2012 11:50 am
by Rich_T
Avantone wrote:
Like a Vespa
[/quote]
Like a lot of things with a billet case. 60 stroke, 76mm bore there is an LC head to suit and a special monster crank with CR250 rod.
Big Block kit will be supplied with 66mm 350LC piston up to 66.5mm then there are all other options available with laser cut packing plates including TS1, DT175 and IT200 pistons. If the economics work out I'll make a dedicated range of pistons for big and small block kits.
Posted: Mon Dec 24, 2012 2:16 pm
by Avantone
Rich_T wrote:Avantone wrote:
Like a Vespa
Very impressive. Commercial or personal project?
Posted: Mon Dec 24, 2012 6:26 pm
by Rich_T
A bit of both, tooling for head, cylinder and manifold is done. Crank is designed (60 stroke, 60mm wide, CR250 rod), ignition and piston are available (RS125). It is only the cases that are missing......at the moment.
Posted: Mon Dec 24, 2012 7:27 pm
by CANbus
Ie is it oversized to promote cooling such as the TT3?
Did you test proto type? If yes what we're the results?
Good job.
Posted: Mon Dec 24, 2012 9:56 pm
by RICSPEED
have i let a cat out of the bag too soon here ???
Posted: Mon Dec 24, 2012 10:26 pm
by Darrell Taylor
good to see the big blocks appearance,should be a good performer,any pics of the ports within the bore,im interested to see the new profile
i like the cast choice ,in a world of everchanging fuels and situations where big car manufacturers are struggling with plating systems its a safer option ,also a few less processes keeps costs down
the other benefit is a nip on an iron kit stands a good chance of cooling down and firing back up or a clean up job but many a nip on a plated cylinder will be game over except for the odd gilardoni and poeton systems that survive well
the new year motor is that correct 60 stroke 76 bore ,272cc ,is the short stroke design part of a retro fit option to std cases as without constrainst on case/webs/cylinder as all are new redesigns then a long stroke design and its superior port area benefits would be an obvious choice ?
