Page 3 of 5
Re: 12V DC CONVERSION VARITRONIC-HOW TO
Posted: Fri Jan 25, 2013 9:23 pm
by joespeed
wack 63 wrote:If you look here
http://www.uk-motoplat.com/gallery.html at the Beta 3 stator this is basically what the varitronic uses.I spoke to the chap regarding rewiring the stator for more power but he said that it is not just a case of doing this as the magnets have an influence as well plus it was about £130
I think the CDI controls the retard as there are no electronics built into the stator .As for an earth for the lighting coils I will have to look at the spare stator I have to see if it could be converted for full DC.
hi wack,
did you get any further with this dc conversion or whether it is possible or not?
Posted: Fri Jan 25, 2013 9:46 pm
by wack 63
Oops,forgot to look but I can tell you that all the wiring is encased in a resin where it joins the coils because I removed it to get a continuity reading . I'll have a look tomorrow but don't recall an earth to the backplate.
Posted: Sun Jan 27, 2013 7:18 pm
by wack 63
The lighting coils are earthed one end to the stator then the first coil is wound in series to the other 2 and terminating at the yellow / white wire(main lighting).The last coil is double wound with the regulator DC feed which is the red/white wire if that makes sense.
Posted: Sun Jan 27, 2013 8:14 pm
by joespeed
wack 63 wrote:The lighting coils are earthed one end to the stator then the first coil is wound in series to the other 2 and terminating at the yellow / white wire(main lighting).The last coil is double wound with the regulator DC feed which is the red/white wire if that makes sense.
so can it be converted to full dc power and a battery?
Posted: Sun Jan 27, 2013 8:45 pm
by soulsurfer
Posted: Sun Jan 27, 2013 9:38 pm
by martinr
call me daft but wouldnt it be easier to put a battery on and run everything from that. and charge the battery from the varitronic simples
Posted: Sun Jan 27, 2013 9:44 pm
by soulsurfer
martinr wrote:call me daft but wouldnt it be easier to put a battery on and run everything from that. and charge the battery from the varitronic simples
It only has trickle charge DC, so running everything, the battery would soon discharge.
Posted: Mon Jan 28, 2013 6:27 pm
by martinr
i run a speedo a taco a volt meter a sevo choke a rear light and brake light 4 indicators an alarm and a programable logic controller all with a 3.4ah battery and its fine batt is allways charged. its only the headlight i run on ac
Posted: Mon Jan 28, 2013 7:17 pm
by soulsurfer
martinr wrote:i run a speedo a taco a volt meter a sevo choke a rear light and brake light 4 indicators an alarm and a programable logic controller all with a 3.4ah battery and its fine batt is allways charged. its only the headlight i run on ac
Hi Martin, By diverting current away from the AC circuit, does that give a brighter headlamp?
Posted: Mon Jan 28, 2013 9:47 pm
by martinr
