Re: Effect of humidity and air temperature on carb performance
Posted: Sun Jan 11, 2009 12:20 am
I'd leave that to Joan Armatrading.storkfoot wrote:I'll drop the pilot and see how it goes
ah ok. what carb spec etc? I would check air screw then maybe drop as you said. Forget plug chopping to check lo end running. In my experience plug chops only really indicate when flat out as the oil doesnt tend to burn off too well at low rpms/ throttle openings and its hard to see. A good dyno operator could help better to sort this once and for all.storkfoot wrote:tony wrote:bloody ell yer confusing me now!
Is it running rough at mo? Does the bike sort of die when you open the throttle?Generally, it's running fine. It's just too bloody cold at the moment to do another series of plug chops
When it's damp, moist air it dies somewhere on the pilot. You pull the clutch, drop the revs and then rev it whilst letting the clutch out and it sort of clears. The carb has a RamAir through the panel. It only does this on damp days. Conversely, when it's cold and not damp, performance is so much better than usual.
you'll have to explain that one to me Dandrunkmunkey6969 wrote:I'd leave that to Joan Armatrading.storkfoot wrote:I'll drop the pilot and see how it goes
That's what I would have thought, it makes sense that you would need a richer mixture if its cold, thats why you need the chokestorkfoot wrote:Cheers, Tony. I'll try the air screw tomorrow and may be flick the choke on when it bogs/dies to see what happens. Thanks again
Choke is needed when the engine is cold because a slow cranking speed with resulting poor airflow will cause poor atomisation of the fuel, also no heat is present in the inlet manifold or cylinder head to assist in fuel vaporisation. Much of the fuel will condense on the cold inlet manifold walls so the mixture must be enriched for the engine to run properly until warm.coaster wrote: That's what I would have thought, it makes sense that you would need a richer mixture if its cold, thats why you need the choke![]()
colin
