t5 kegra 190 or malossi 172
soulboy
never heard of them ill take a look cheers joe ;)
gimp1971
Main scooter: vespa t5
if you cant get a Taffy Scorpions are very good with a 172 dont forget you can buy a taffy for a 200 and just get a downpipe from welsh scooter parts which is the route i took was £60 for pipe and £50 for downpipe and saw one go for about £30 the other day
C*NTSPEED
GEMINI S.C.
BLACK WIDDA'S S.C.
mr.c
noob
i have a mb 170 kit goin on ebay soon done around 700 mile the tunning work marks done is a work of art cost me £470 wanting £350
C*NTSPEED
no good when the malossi is a quicker kit and cheaper tho......
GEMINI S.C.
BLACK WIDDA'S S.C.
ducksta
just having a suzuki conversion done by martin at chislespeed will be 171cc , running standard carb 21 tooth cluth, revolver exhaust will run it on 3%fully synthetic .
C*NTSPEED
Why 3% and why fully synth on a steel liner? Even on plain 172 I only ran at 2% and on rock oil semi synth?
GEMINI S.C.
BLACK WIDDA'S S.C.
ducksta
so you would say 2% semi is ok, (i run the malossi 172 on 2% ) just when i had the pollosi done harry barlow said 3% fully synth apart from that spec seems ok?
C*NTSPEED
ducksta wrote:so you would say 2% semi is ok, (i run the malossi 172 on 2% ) just when i had the pollosi done harry barlow said 3% fully synth apart from that spec seems ok?
harry likes to be over cautious hence the name huge jet harry :lol:
GEMINI S.C.
BLACK WIDDA'S S.C.
roadrunnerian
Hi i run one of martins 171 conversions i run at 3% they are a good kit power comes in like a mule kick i have the jl rz rhs pipe and standard carb with 21 tooth. hope you enjoy your kit as much as i do. ;)
