Page 3 of 9
Re: My Li225 Special
Posted: Tue Jul 10, 2012 9:16 am
by Minority
Toddy wrote:
Is that a home made set up not the Spanish type throttle return spring?
Completely home brewed
Posted: Tue Jul 17, 2012 3:05 pm
by Minority
The homemade engine stand has worked out quite nicely. Its on wheels so I can move it around the garage.
The reason I took the motor out (well the excuse anyway, I just love tinkering), was that when I had the carb off and looked down the manifold I noticed a
huge step to the inlet port in the cylinder (its a Mugello cylinder
and manifold, you'd think they could get it closer than that).
I decided I would have to strip the top end and match the inlet and exhaust manifold at least. It also gives me a chance to check the squish and port timings.
Posted: Wed Jul 18, 2012 2:54 pm
by Minority
Took the cowling off today and I've solved the mystery of the badly matched Mugello cylinder & manifold......
If you can't work it out from that pic, this one may help!
Yes, Ive got a Rapido top end with a Mugello manifold.
At this stage I don't know if it's a "Race" or "Classic" and what size it is!
More concerned with what crank it's got, supposed to be an AF race crank, but now who knows?
Posted: Thu Jul 19, 2012 6:02 am
by Dryballs
I think you'll be better with a rapido cylinder anyway!
I have heard the mugello clinders arent all that good in terms of performance.
I got my rapido to about the same performance level as my TS1
Posted: Thu Jul 19, 2012 10:17 am
by Minority
Dryballs wrote:I think you'll be better with a rapido cylinder anyway!
Yes, I'd heard mixed reviews about the Mugello kit, but I always thought my "Mugello" went quite well, now I know why.
Which Rapido have you got and what have you done to get TS1 performance?
When I get mine stripped and I find out exactly what I've got, I may have to re-evaluate which way I want to go (maybe a reed valve setup).
John
My Li225 Special
Posted: Thu Jul 19, 2012 10:34 am
by Dryballs
The best thing you can do is get a race tour piston from mb
If you reed valve it just get a ts1 piston
The standard asso piston is just too heavy
Posted: Fri Jul 20, 2012 9:23 am
by Minority
Got my Mtech unit to fit when everything is back together. Martin at Cheselspeed was really helpful and made my long distance purchase a pleasurable experience.
Posted: Fri Jul 20, 2012 1:11 pm
by Minority
Well started the strip down and it's a 225cc (70mm bore), 2 ring piston (don't know what variety) and a "Rapido Classic" (rough initial port timings Ex 168, transfer 120, haven't got down to inlet) so room for a bit of porting.
I think the squish is about 2mm (we'll have to sort that) and the head gasket is 68mm
Is this common on a 70mm bore?
I figure if I raise the cylinder by about 1mm I'll end up with about 172 exhaust and 126 transfers, and if I do away with the head gasket (1.5mm thick) squish should be about right.
Anyway, at least the picture is becoming a bit clearer now.
Posted: Wed Sep 26, 2012 1:52 pm
by Minority
A couple of pics of the bracket I made up to hold the sensor for my new SIP speedo.
I decided to "pick up" from the studs on the rear hub and I'm quite happy with how the bracket looks.
I've just got to drill and tap for a couple of grub screws and give it it's final polish and it will be finished, just hope it all works ok!
Posted: Wed Sep 26, 2012 2:21 pm
by RICSPEED
cool .. nice scoot mate .. love the little details too
