Page 3 of 9
Re: Cutdown ....work in progress
Posted: Sun Jun 17, 2012 7:32 pm
by rondon
that sir is VERY TRICK
Posted: Mon Jun 18, 2012 10:26 am
by Fenian Mick
mick1 wrote:very nice........what did you do on the 2nd day of the build ?
Ha Ha....most of it done over the last 12 months. Just never got round to posting on here.
I had 2 attempts at the modified head set top accommodating the Vapour speedo.
The first go i made a facia and welded it in position but it did not allow enogh room for inside controls.
The second attempt i bought a cnc machined holder for the Vapour from a moto x dealer and welded that to the original then fettled it.....now much more room and cosmetically look better when painted
I fitted all hoses and cables and loom through the frame and located ignition components under the frame below the seat.
A mate of mine does all sorts of coatings, so he did a black heat dispersant coating on the head , barrel and manifold.....its supposed to improve heat dispersal by 15 % ??
finally decided on the frame set up and removed rear tube and mudguard brackets( still attached in pic) and sent all off to the painters.
fingers crossed all the ideas look good when the painters worked his magic
Posted: Mon Jun 18, 2012 12:41 pm
by Fenian Mick
Posted: Mon Jun 18, 2012 3:26 pm
by Minority
That paint is stunning!
Can't wait to see the finished article.
Posted: Mon Jun 18, 2012 11:01 pm
by RICSPEED
Fenian Mick wrote:
what exactly is the foot pegs mounted to ??
i ask
as i need to make mine much lower .. i get cramp within minutes as they are
Posted: Mon Jun 18, 2012 11:21 pm
by MADSPEEDRB260
Looking good well done.
Posted: Tue Jun 19, 2012 12:04 pm
by Fenian Mick
i ask
Ali plate shaped to chaincase then welded, drilled and tapped. Casing bows when welded.... i bolted it down to an old engine case and had it clamp at both ends but it still bowed a bit.......but the gasket dresses up again with a bit of careful work.
Posted: Tue Jun 19, 2012 1:00 pm
by Minority
Going to mess up fitting that nice shiny exhaust!
Posted: Tue Jun 19, 2012 3:00 pm
by RICSPEED
Fenian Mick wrote:
thanks
Posted: Tue Jun 19, 2012 3:54 pm
by soulsurfer
Fenian Mick wrote:
Would that be strong enough to stand constant use, I wouldn't think the chaincasing has that much strength?
