Page 3 of 4
Re: Dragging clutch / weird scraping / petrol in gearbox oil
Posted: Sun Jul 01, 2012 10:57 am
by goldeneye
KACE was the clutch i put in mine gaz, was alright. i stripped it and gave it the once over, and replaced the the springs with X strong DR springs, as i always do on me own clutches for when i"m 2"s up. i was actually impressed by the cork plates, looked good and thick, and all the oil ways were cleaned out. the castle nut i got for it was made of chocolate though! stripped it while tightening it up. used a piaggio one i had instead.
Posted: Mon Jul 02, 2012 1:17 pm
by mushroom
It's a polini barrel, piston and modified head with beedspeed written on it
Are these any good ? I need it to be reliable, not bothered about going fast
Posted: Wed Jul 04, 2012 4:08 pm
by cit205
I'd be inclined to flog the top end and fit a standard one for your requirements ,if you're after a trouble free work horse of a p2.
Posted: Wed Jul 04, 2012 6:47 pm
by goldeneye
wot he said.
Posted: Wed Jul 04, 2012 7:23 pm
by mushroom
Where can you buy a standard barrel, piston and cylinder head ?
Posted: Thu Jul 05, 2012 8:14 am
by cit205
Posted: Fri Jul 06, 2012 9:23 pm
by mushroom
Might stick with the polini as it was working fine before the clutch problems
I've stripped it down and split the case but found quite a few brass shards and flakes around. There's some in the clutch side oil seal and bearing, a huge bit was stuck in the kickstart spring.
Could it be off this ?
Posted: Fri Jul 06, 2012 9:41 pm
by bazman
More than likely to be your clutch shim by the looks of it.
http://beedspeed.com/product_info.php?c ... ts_id=1841
Posted: Fri Jul 06, 2012 9:53 pm
by mushroom
Thanks, where does that shim go ?
Posted: Fri Jul 06, 2012 9:55 pm
by bazman
