Page 3 of 3
Re: malossi 210 wont go over 55
Posted: Sat Apr 07, 2012 11:08 pm
by Muttley McLadd
It's not something as simple as air filter blocked, is it?
Posted: Sat Apr 07, 2012 11:57 pm
by Danger
open mouthed 30mil
Posted: Sun Apr 08, 2012 7:15 am
by drunkmunkey6969
Put your old pipe on and see how it responds......
Sent from my HTC Sensation using Tapatalk
Posted: Sun Apr 08, 2012 8:14 am
by bazman
drunkmunkey6969 wrote:Put your old pipe on and see how it responds......
Keep up at back, he said he no longer has it !!
:biggrin: ;)
If you could get a loan of a different exhaust just to compare then that could be ruled out?
Posted: Sun Apr 08, 2012 10:28 am
by Stokie
Did you fit the circlips in the piston?
A Jaguar motor development engineer with a 1st class honours degree forgot the circlips when he built his 225 Lambretta motor - it wouldn't go past 55mph either ......
Posted: Sun Apr 08, 2012 12:18 pm
by Danger
yip the old pipe has gone , have an old simo im going to try on it when i get the chance just to rule the new pipe out as the scooter is at another m8 of mines to have the timing set , and yes the piston circlips are on well they were the last time i looked lol,
Posted: Sun Apr 08, 2012 11:29 pm
by john.t5
Danger, what's the story with the crank in this? Looks like the keyway has been filled and recut, anyhoo due to that the timing was at about 10deg btdc so set now at 18, haven't had it out but would timing that advanced be likely to be the cause?
Posted: Sun Apr 08, 2012 11:52 pm
by Danger
john its a new crank , the old flywheel split two woodruff keys so i got the flywheel thats on it now an put it on, timing that far out it could be im not sure m8 give it a run an see
