AF rapido 225 infos
cezeta wrote:...its down to how chunky the rod is, if it protrudes out of the webs too far then it will hit.
so then it needs some taken out of the casing behind the crank..?
only sure way to tell is to build it up and check the clearance I guess, then strip it all down again if it needs some... :evil:
but I'll get the rod fitted to the crank first...
