Page 3 of 5
Re: shrinking pistons?
Posted: Thu Jan 12, 2012 7:54 pm
by CANbus
Surely if the pistons are wearing excessively there has to be mechanical interference between the bore and the piston? Wouldn’t that bring the fuel/oil ratio into question?
Posted: Thu Jan 12, 2012 8:04 pm
by CANbus
ok
I will run it by our metallurgists and see if they have any thoughts.
Posted: Thu Jan 12, 2012 8:05 pm
by jason frost
mark wrote:I have asked what tools were called that were used and I can now say
Piston measured with external micrometer, bore with a bore comparator
Nice one same as me
Posted: Thu Jan 12, 2012 8:10 pm
by mark
the piston IS NOT WORN
Posted: Thu Jan 12, 2012 8:13 pm
by CANbus
Roger mother bird
Posted: Thu Jan 12, 2012 8:19 pm
by jason frost
eden wrote:how Ive understood it, they aren't waring away, they are apparently physically shrinking
From what has been said so far it would seem so, but without knowing all the sizes of the piston before it was fitted shrinking is an odd thing to say to me. Top to bottom, side to side would all be different and thats not a thing I would check before fitting, you would need to know the size of the piston at all these points first then check them again to say the whole piston had physically shrunk or am I missing something ?
Posted: Thu Jan 12, 2012 8:24 pm
by Muttley McLadd
Could we interest these pistons in a wafer thin mint?
Posted: Thu Jan 12, 2012 8:30 pm
by mark
its quite simple really
A : the engine was built with 4 thou of clearance of piston to bore
B: it ran for 500 miles approx and got exceedingly hot the more miles done ,no distance was more than 25 miles at any time.
C: when stripped to find problem piston to bore clearance was 6.5 thou, which is 2.5 thou more than it was when measured in the same position
D: the bore and the ring gap are IDENTICAL to the original build and the piston is not
to me and my engine builder this equals a piston that has shrunk, it is a piston no more it is dead.
do you have another explanation for this pheonoman ?
Posted: Thu Jan 12, 2012 8:44 pm
by dirtyhandslopez
Answer has already been aluded to Mark. It's the silicone content.
Think about it, when you caulk a window with silicone, after a while(granted, years) the silicone will start to shrink and you have to do it again.
In an engine the heat factor is a lot more than on a window, therefore the deteriation will happen far more quickly.
What may have happened is that there was a bad batch of pistons made with too much silicone in them. Great for not seizing and or a race meet, but no good for a road scoot. Everything is a trade off.
Posted: Thu Jan 12, 2012 8:47 pm
by mark
that is exactly what the metallurgist i spoke to today said , he said he may be able to test the piston when he gets back from his holidays
