Page 3 of 5
Re: 225
Posted: Mon Nov 14, 2011 10:24 pm
by Muttley McLadd
Considering the Supertune Avanti TT3 kit comes with a head as well, it looks remarkably good value.
(others might... I've not looked at them)
(apart from the TS1, and mine came fettled, and with a head)
Re: 225
Posted: Mon Nov 14, 2011 10:50 pm
by tony
Ok.. so its not that bad then the pricing. I had a look and the top spec RT TS1 is nearly £900 and by the looks of it the kit above is a 2 port ally piston port barrel for £736?
The MB cranks are expensive too but good quality I am sure and something MB would recommend with his kit. I have to say fellas its not looking too bad to me. The pipe is dearer sure and for the reasons I posted.
Have a look at high end smallie stuff these days.. falc kits are now £600,cranks £534 and are not a direct fit.. the clutch is £327 and the pipe £465 from sip.
The SM of course comes complete with a head. Its vital to the whole thing.
I am sure some graphs will be out there soon.. and I would expect a demo bike too. (thats what i would do anyway)
Re: 225
Posted: Mon Nov 14, 2011 10:57 pm
by OAP
Avanti TT3 Kit Content
Avanti Cylinder Number Piston size Ring Gap
Cylinder Head
Piston
Cowl
4 x cylinder studs
4 x 8mm long head nuts
4 x 8mm flat washers
4 x 8mm wavy washers
2 x 7mm brass exhaust nuts
2 x 7mm wavy exhaust washers
1 x 7mm inlet nyloc nut
1 x 7mm long inlet bolt
2 x 7mm wavy washers
2 x 5mm bolts
2 x 5mm wavy washers
2 x 5mm plain washers
3 x 8mm button bolts
3 x 8mm plain washers
3 x 8mm wavy washers
3 x Base gaskets (0.4mm, 0.75mm & 1.00mm)
1 x inlet gasket
1 x exhaust gasket
2 x Avanti TT3 stickers
Fitting Instructions
Running Instructions
Checked:
Date:
Re: 225
Posted: Mon Nov 14, 2011 11:08 pm
by Muttley McLadd
A Honda RS125 race cylinder will see no change from three grand,
on its own.
Re: 225
Posted: Mon Nov 14, 2011 11:31 pm
by tony
I know... I have seen em and worked on these motors.
lauro (falc) did his own one for 1600 euros though. He was a HRC technician.
Re: 225
Posted: Mon Nov 14, 2011 11:39 pm
by tony
yep seems like a top fella
Re: 225
Posted: Tue Nov 15, 2011 5:00 pm
by soosh
I've blasted it down the road and it works straight put of the box.
Fantastic kit and looking forward to seeing what others can get out of it too.
All is good down the cow shed.I'm surprised nobody else has thought of the extra fining like on this kit though.
Re: 225
Posted: Tue Nov 15, 2011 7:14 pm
by Muttley McLadd
soosh wrote:I've blasted it down the road and it works straight put of the box.
What polish do you use?
soosh wrote:I'm surprised nobody else has thought of the extra fining like on this kit though.
To be fair.. other dealer(s) have invented things like
stainless steel and
pistons, without getting their knickers in a twist
Re: 225
Posted: Tue Nov 15, 2011 7:20 pm
by soosh
Re: 225
Posted: Tue Nov 15, 2011 9:26 pm
by cezeta
i know the ron moss kit has more potential than for what i will use it for but im favoring it for its simplicity and cooling ability.
the ron moss clubman liberated my sluggello so ill be using it on the ron moss kit when im ready to keep it as lambretta ish as possible....and im going to give the tried and tested 24mm mikuni a go with it. i know ill lose a bit of power but its never enough to worry about if used on a decent kit.
i imagine the supermonza is more powerful but thats not everything and im not keen on having to buy EVERYTHING on the menu. makes it a few grand compared to a ron moss onto my existing motor for 500, i simply dont have the budget anymore for £2-3k motors.
ron so far has been easy to deal with and is a regular humble fella which is a pleasant change too.
